Add to cart help
Thread begun 2/02/2011 6:02 am by sabastian130416448 | Last modified 2/04/2011 6:45 am by Jason Byrnes | 3340 views | 5 replies |
sabastian130416448
Add to cart help
Hey guys.
I bought Data Assist With the Dynamic Suit. I have created my product_result and product_detail pages and everything is working great.
The problem I know have is this. When I add a "Add to Cart" button, I am using Ecart 5.0.3,
and I test the page every time I go to view cart it keeps on telling me the cart is empty.
My page above the <head> tag looks like this.
//WA eCart Include
require_once("../WA_eCart/eCart1_PHP.php");
<?php require_once('../Connections/Shop.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
$eCart1->GetContent();
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$Paramid_tb_WADAcastaic = "-1";
if (isset($_GET['id_tb'])) {
$Paramid_tb_WADAcastaic = (get_magic_quotes_gpc()) ? $_GET['id_tb'] : addslashes($_GET['id_tb']);
$ParamSessionid_tb_WADAcastaic = "-1";
if (isset($_SESSION['WADA_Insert_castaic'])) {
$ParamSessionid_tb_WADAcastaic = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_castaic'] : addslashes($_SESSION['WADA_Insert_castaic']);
$Paramid_tb2_WADAcastaic = "-1";
$Paramid_tb2_WADAcastaic = (get_magic_quotes_gpc()) ? $_GET['id_tb'] : addslashes($_GET['id_tb']);
mysql_select_db($database_Shop, $Shop);
$query_WADAcastaic = sprintf("SELECT id_tb, name_tb, desc_tb, price_tb, image_tb, link_tb, keywords_tb, group_tb, fulldesc_tb, fulldesc2_tb FROM castaic WHERE id_tb = %s OR ( -1= %s AND id_tb= %s)", GetSQLValueString($Paramid_tb_WADAcastaic, "int"),GetSQLValueString($Paramid_tb2_WADAcastaic, "int"),GetSQLValueString($ParamSessionid_tb_WADAcastaic, "int"));
$WADAcastaic = mysql_query($query_WADAcastaic, $Shop) or die(mysql_error());
$row_WADAcastaic = mysql_fetch_assoc($WADAcastaic);
$totalRows_WADAcastaic = mysql_num_rows($WADAcastaic);?>
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
if (isset($totalRows_WADAcastaic) && $totalRows_WADAcastaic > 0) {
$row_WADAcastaic = WAEC_findRecordMySQL($WADAcastaic, "id_tb", $ATC_itemID);
if ($row_WADAcastaic) {
$ATC_itemName = "".$row_WADAcastaic['name_tb'] ."";// column binding
$ATC_itemDescription = "".$row_WADAcastaic['desc_tb'] ."";// column binding
$ATC_itemThumbnail = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_WADAcastaic['price_tb'] ."");// column binding
mysql_data_seek($WADAcastaic, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA Application Builder Delete
if (isset($_POST["Delete_x"])) // Trigger
$WA_connection = $Shop;
$WA_table = "castaic";
$WA_redirectURL = "castaic_Results.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "id_tb";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_Shop;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
// WA eCart Redirect
if ($eCart1->redirStr != "") {
session_commit();
header("Location: ".$eCart1->redirStr);
Before I was using Ecart 5.0.2 and I added my product_id manually but now that I want to get the Info from the database to populate it automatically it doesn't want to work.
Can anybody please give me some advice on how to fix my problem.
Thanx
First, we need to make sure that your server is properly set to store session information.
use the sessionTest page from the following post to test the servers session management settings;
showpost.php?p=23826&postcount=2
If yoou are still having a problem, please compress the page into a zip archive and send the zip file instead of pasting the code into the message, also if you could provide a link where i could see the problem, that would be helpfull.
sabastian130416448
Hallo Jason.
I did the test and I am sending two screen captures with to show you what happen when I press the two links. They seem to be workin fine.
I uploaded the page you requested as I am still working on the site on my pc. The link is
castaic_Detail.php
I also am sending the page in a zip file like you asked.
I hope there isn't a major problem.
Thanx
try changing:
session_commit();
sabastian130416448
Hey Jason.
Got the problem fixed.
Had two e-carts and the buttons and my cart page weren't linked to the same one.
Thanx
Ok, Glad to hear it is working.
