another issue with the automated procedures...
Thread begun 2/02/2011 1:46 am by m.finelli420407 | Last modified 2/02/2011 4:19 pm by m.finelli420407 | 3676 views | 5 replies |
m.finelli420407
Hello again.
It seemed I solved a problem when another comes up.
I've preformed the automated creation of the Insert, Update, Detail, Result and Delete pages with the Data Assist wizard.
I've managed to set the upload files where needed with Digital File Pro... but when I type the data into the fields, what I get are not the texts I've inserted but only a "0" for each field (see the image attached).
Consider the following:
I have a MySQL db where there are two tabels: "Album" and "fotografie" (photos in Italian). The "fotografie" table is:
foto_id, int 11, unsigned, not null, autoincrement
caption varchar 100 not null
captioneng varchar 100 not null
foto_big varchar 255 not null
album int 11
I'm testing these pages on my local server managed with MAMP
Can you help me?
Thanks!
Michele
m.finelli420407
this solved, but again...
Hello
I've solved the previous issue (changing the field values to text into the wizard view), but now I have a new matter:
When i click on the "delete" button i receive a blank page with this statment: "Unknown column 'undefined4undefined' in 'where clause'".
Here you have the code of the page:
<?php require_once('Connections/foto.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$Paramfoto_id_WADAfotografie = "-1";
if (isset($_GET['foto_id'])) {
$Paramfoto_id_WADAfotografie = (get_magic_quotes_gpc()) ? $_GET['foto_id'] : addslashes($_GET['foto_id']);
mysql_select_db($database_foto, $foto);
$query_WADAfotografie = sprintf("SELECT foto_id, caption, foto_big FROM fotografie WHERE foto_id = %s", GetSQLValueString($Paramfoto_id_WADAfotografie, "int"));
$WADAfotografie = mysql_query($query_WADAfotografie, $foto) or die(mysql_error());
$row_WADAfotografie = mysql_fetch_assoc($WADAfotografie);
$totalRows_WADAfotografie = mysql_num_rows($WADAfotografie);?>
// WA Application Builder Delete
if (isset($_POST["Delete_x"])) // Trigger
$WA_connection = $foto;
$WA_table = "fotografie";
$WA_redirectURL = "fotografie_Results.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "foto_id";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_foto;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Delete fotografie</title>
<link href="WA_DataAssist/styles/Modular_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADADeleteContainer">
<?php if ($totalRows_WADAfotografie > 0) { // Show if recordset not empty ?>
<form action="fotografie_Delete.php?foto_id=<?php echo(rawurlencode($row_WADAfotografie['foto_id'])); ?>" method="post" name="WADADeleteForm" id="WADADeleteForm">
<div class="WADAHeader">Cancella Fotografia</div>
<p class="WADAMessage">Sei sicuro di voler cancellare questa fotografia?</p>
<p class="WADAMessage"><img src="foto/<?php echo $row_WADAfotografie['foto_big']; ?>" width="200" height="200" /></p>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">foto_id:</th>
<td class="WADADataTableCell"><?php echo($row_WADAfotografie['foto_id']); ?></td>
</tr>
<tr>
<th class="WADADataTableHeader">titolo:</th>
<td class="WADADataTableCell"><?php echo($row_WADAfotografie['caption']); ?></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Delete" id="Delete" value="Delete" alt="Delete" src="WA_DataAssist/images/Pacifica/Modular_delete.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="fotografie_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Pacifica/Modular_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADADeleteRecordID" type="hidden" id="WADADeleteRecordID" value="<?php echo(rawurlencode($row_WADAfotografie['foto_id'])); ?>" />
</div>
</form>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_WADAfotografie == 0) { // Show if recordset empty ?>
<div class="WADANoResults">
<div class="WADANoResultsMessage">No record found.</div>
</div>
<?php } // Show if recordset empty ?>
</div>
</body>
</html>
mysql_free_result($WADAfotografie);
Any suggestions?
Michele
Double click on the Delete record server behavior and make sure a valid data type is selected for the ID column.
m.finelli420407
checked...
The Data type of the Id key column (foto_id) is a numeric value, so it is correct.
Any other suggestion?
Michele
you're code does not have an error in it. this code will not generate the error you are getting.
I suspect that the code running on the site is not the same.
Delete the delete page from the remote site and upload it again.
m.finelli420407
solved!
Jason,
I went back to the process and re-select the data type to "numeric".
Now everything works perfectly!
Thanks!
Michele
