CAPTCHA field causing Insert Record to not occur
Thread began 2/01/2011 8:31 pm by holt3937911 | Last modified 2/03/2011 7:00 am by Jason Byrnes | 1382 views | 3 replies |
holt3937911
I'm able to create a simple form...and use an Insert Record server behavior to add a record to my database. However when I include a CAPTCHA field using the FB and use Server Validation that is automatically setup for me by FB, the Insert Record no longer works.
It may be my CAPTCHA code. If I purposely type in the CAPTCHA security code that doesn't match the image...I don’t get any error messages stating it wrong…Nor is the Failed Redirect URL invoked (as defined in the Server Validation).
If I type in the security code correctly.....my record Insert doesn’t occur as expected.
I’m a little suspicious of how the WA Server Validation code looks as there doesn’t appear to be anything in it about verifying the Security Code field. I've tried setting up a Server Validation specifically for the Security Code using "Like Entry" with Server variable from WA Server Validation Entries (Security Coder) with the Security Code field in my form...but not been very successful in getting Server Validation to work for the Security Code field or the the Insert Record server behavior.
Any suggestions.
emailformTest2.php.zip
When adding the captcha validation, dont use the WA Server Validation Entries (Security Code) variable, this is created only when the validation fails.
Use the Security Code binding under the Form binding group, and set it to compare to the captcha_Security_Code session variable.
holt3937911
Noticed Different Form Field Definitions
First...THANKS!
OKay......I recreated the entire page from scratch.....as I didn't see a session variable. Once I had the new page posted....it all works as expected.
On more than one occasion....I noticed that the form field definitions are created differently (e.g. us of ValidatedField("NewTestPage","Full_Name"):"")) ..but I have never been able to figure out what I've done differently. Below is an example of a form field that is working with CAPTCHA and Server Validation. This form was created initially with CAPTCHA field in the form.
<div class="fullColumnGroup">
<label for="Full_Name" class="sublabel" > Name<span class="requiredIndicator">&nbsp;*</span></label>
<div class="errorGroup">
<div class="fieldPair">
<div class="fieldGroup"> <span id="Full_Name_Spry">
<input id="Full_Name" name="Full_Name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("NewTestPage","Full_Name"):"")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Full_Name_ServerError');"/>
<span class="textfieldRequiredMsg">Please enter your name</span> </span>
if (ValidatedField('NewTestPage','NewTestPage')) {
if ((strpos((",".ValidatedField("NewTestPage","NewTestPage").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Full_Name_ServerError">Please enter your name</span>
<?php //WAFV_Conditional NewTestPage.php NewTestPage(1:)
</div>
</div>
</div>
This is an example of form field when the page wasn't working where I created the form...saved it..then added the CAPTCHA field......any idea what I may be doing to cause the code below to be generated....other than what I just stated. I've spent entire day trying to figure this out....thinking it has something to do with my validation and record insert not working.
<input id="Full_Name" name="Full_Name" type="text" value="" class="formTextfield_Large" tabindex="1" />
<span class="textfieldRequiredMsg">Please enter your name</span> </span> </div>
</div>
</div>
</div>
the validated entries code from the first example does 2 things:
1) In the bindings panel, there is a validated entries binding group. Use these bindings for the initial value of the form elements to retain valid entries in the form when it it fails validation.
2) On the server behaviors panel, click the plus button and select WebAssist -> Validation -> Validation show if. This behavior is used to show an error message on the page when validation fails.
