encode html entities | unaddressed!!!
Thread begun 2/01/2011 10:39 am by robert254422 | Last modified 2/01/2011 11:27 am by Jason Byrnes | 2438 views | 3 replies |
robert254422
Hello,
Using html editor 3.0
formatting presets are: encode both + encode html entities turned on
When directly typing | character inside the editor this character does not get encoded... In combination with update and insert actions on that page you get mad errors because of the unaddressed | character... It also does not get encoded when inserted using the insert special characters feature...
When | is added as additional to encode character in the settings... It does nothing when typed directly in to the editor and generates a undefined message in the source code of the item when inserted using the insert special character feature...
| Is not the type of character I would like to leave unaddressed in an advanced html editor that has to work in forms that have insertion or update actions (built with data assist by the way)...
I really hope you can fix this asap because for me this is a major reason to stop using this product since my form actions get messed up because of it.. I believe I tried every possible combination inside the formatting settings but don't want to rule out myselve as the cause completely so if I missed something...
Otherwise very pleased with the editor and WA products in general...
WKR RV...
add the following code at line 1 of your insert and update page:
if(!empty($_POST)) {
    foreach(
$_POST as $key => $value) {
$_POST[$key] = str_replace("|", "|", $value);
to correct the issue.
hmmm, the forum is encoding the pipe html entoty.
in this line:
the second pipe should be "& # 1 2 4 ;" (Without the space between each character, i left them in so it would not get encoded).
robert254422
TYVM for the quick reply... Suggestion works...
To be clear... When | was added as additional to encode character in editor settings and then typed straight in to the editor it actually also gets changed to undefined and not like I stated before leaves it as it was... So atleast adding it made the | harmless to the insert and update functions...
For your advice to work I first had to remove the added | as additional to encode character from the settings of the editor...
TYVM AND WKR RV
Glad to hear it is working.
