Install Path Error on Sub Domain Install
Thread begun 2/01/2011 10:07 am by robbc199761 | Last modified 2/03/2011 8:56 am by Jason Byrnes | 2760 views | 4 replies |
robbc199761
Hello,
I installed Photo Gallery in a sub domain and the direct link to the gallery states it should be this.
index.php?gallery=1&theme=dark
That is not the case as it should be index.php?gallery=1&theme=dark
Seems it is adding /brabandfilmvideo/ to the URL which is the sub directory and sub domain of cpcomhosting.com.
Where and how exactly do I change this?
see this post for an update that should correct the problem:
showpost.php?p=81968&postcount=5
robbc199761
Still Can't Log In
I downloaded the global.php file and uploaded it and I still can't log in.
I logged into the database and looked at the user and passord in the wa_settings and used it to try and log in /powergallery/admin_gallery/index.php and it says the user/pass are incorrect.
Both MySQL and PHP are 5.0.
What now?
index.php
robbc199761
Admin Login Problems
Any response to this problem? I own almost every product you have for years and the response time is getting really slow. I need to get this resolved right away.
