eCart doesn't modify Powerstore
Thread begun 1/31/2011 8:43 pm by brandoli400690 | Last modified 2/02/2011 9:23 am by Jason Byrnes | 1939 views | 1 replies |
brandoli400690
I purchased eCart (actually entire supersuite) to modify taxes and shipping on Powerstore3 and it won't hold any of the changes I programmed for either taxes or shipping.
First it applied a completely wrong tax code, then they disappeared altogether when I tried to add shipping parameters.
Deadline was last week ....
to be able to edit the power store using eCart, you will need to make sure that the Dreamweaver site is defined correctly.
The Power Store Files must be at the root of the Dreamweaver Site.
Also, make sure that the WA_eCart folder is not set to read only. the files in the eCart folder must allow read and write access.
you say it added a wrong tax code?
how did you set the rule?
How was the code wrong?
are you intending to replace the shipping rules that are already in eCart?
If so, you should delete those rules, then add your new ones.
