wa_appbuilder_php.php not creating library.php file
Thread begun 1/31/2011 8:18 am by ryanteets270615 | Last modified 1/31/2011 3:08 pm by Ray Borduin | 3047 views | 3 replies |
ryanteets270615
I chose the option for the email log in UE4 and it created the wa_appbuilder_php.php file but not the required file that is needed within it: require_once("library.php");
I tried turning off the log and then adding it again and cant seem to get UE4 to create the needed file.
any suggestions?
Did you completely uninstall and reinstall DataAssist when you last upgraded. Dreamweaver has a nasty habbit of not adding new files when you don't uninstall the old version. That sounds like it could be the issue.
Or I have attached a copy of the file to this thread. You can add it to your user configuration folder in the location:
/%appdata%/Adobe/Dreamweaver CS5/en_us/Configuration/Shared/WebAssist/ApplicationBuilder/Helpers
ryanteets270615
Actually the file that is missing is library.php that the server behavior creates in the webassist > database_management folder (library.php) when choosing the option for creating the email log in UE4.
I put the file you posted in there and it works now. I hope that is the same one that is supposed to go there?
Thanks.
Yes, we use that same file in several places, but the version I attached is the latest version that could be used in any.
