Endless Log In Issue
Thread begun 1/31/2011 5:33 am by gpaul | Last modified 1/31/2011 3:32 pm by Jason Byrnes | 5061 views | 7 replies |
gpaul
I am having an issue with log in. I created (not working yet) a download page which requires to be logged in. When you log in, it takes you to your profile page, at the bottom I have put a "download" link to take you to the page, however it takes you back to the log in page, however the second time, the log in fails.
I am attaching the download, login and profile files.
Thank you
Gary
can you send a copy of the WA_SecurityAssist/HelperGropupRules_PHP.php file please.
gpaul
Jason
Thank you for your reply.
can you verify that the helpergrouprules_php.php file was uploaded to the server? Try deleting it from the server, then re uploading it.
gpaul
The file was on the server, I deleted and reloaded. The both files were modified on the same day.
I briefly had it working, but was getting the error that headers had already been sent. I was unable to see any cause for that. I had commented something out, put it back in and the same problem is there, login ok, profile ok, back to login, no work.
Again I am attached the login/profile/download_center.
This is frustrating!
Thank you for all your help.
GAry
to trouble shoot, add the following code on the login page after the body tag:
<pre><?php
if(!session_id()) session_start();
var_dump($_SESSION);
?></pre>
post back the results after trying a test through.
gpaul
This is the message when I first open the login page
<pre>array(0) {
</pre>
There is no message on profile page, however when I am taken back to the second log-in, I get this message,
<pre>array(1) {
["cust_id"]=>
string(1) "1"
</pre>
Gary
