Powerstore 4 and Paypal
Thread begun 1/30/2011 9:42 pm by dave276887 | Last modified 2/22/2011 12:12 pm by Jason Byrnes | 5588 views | 8 replies |
dave276887
Hi
My options are not being listed correctly on the PayPal site and receipt, but good in my database. How do I get the options sent correctly to PayPal as they are called instead of item no etc.
amtcgear.com.au
it depends on which paypal payment you are using.
are you using Payments Standard? Payments Pro? or Express Checkout?
dave276887
I believe I am using express checkout
dave276887
Still Waiting
Hi Jason I still am awaiting for an answer for this, client keeps calling....
in the webassist/plugins/shopping_cart/pp_expresscheckout.pgp file, change:
$WA_PP_ECO_Do_itemized[0][$nextIndex] = "Name" . strval($cartIndex+1) . "";
  $WA_PP_ECO_Do_itemized[1][$nextIndex] = "".$WA_Store_Cart->DisplayInfo("Name")  ."";
  $WA_PP_ECO_Do_itemized[1][$nextIndex] = "".$WA_Store_Cart->DisplayInfo("Name").((strlen($WA_Store_Cart->DisplayInfo("Options")) > 0)?'--'.$WA_Store_Cart->DisplayInfo("Options"):"")  ."";
dave276887
Paypal Options
Thanks Jason, will try this as see what happens.
I could do this in earlier versions of powerstore but couldn't see where to do in PS4
OK
another thing this client wants
I have set up shipping in ecart5 using
subtotal of weight column at various weights equals a different flay rate. This has worked well.
Now he wants to be able to create another rule where the if the total price is greater than 100 dollars then free postage.
Tried
subtotal for the entire cart contents subtotal price for the cart > 100 then flat rate of 0
Doesn't seem to work
What should the trigger be?
Or do I need something else.
you wont create another rule for this, you will need to edit the triggers for the existing shipping rules.
you will need to add the trigger:
subtotal for the entire cart contents subtotal price for the cart < 100
so that they only trigger if the weight is within the certain range AND the total price is less than 100.
the rules on the shipping tab are added up to the total shipping, Setting one rule to have a flat rate of 0 only adds 0 to the total of the other rules, it does negate them.
dave276887
Thanks Jason, this seems to work will check the next few orders to make sure.
Cheers Dave
you're welcome.
