Unordered List definition upsets menu
Thread began 1/30/2011 3:33 pm by clive.henderson222953 | Last modified 1/30/2011 4:29 pm by neilo | 951 views | 1 replies |
Sorry if this is a silly query my css is not too hot.
My horizontal menu worked just fine.
I decided to use images for my bullet points (UL definition)
ul {
list-style-image: url(../images/bullets/tick_green.png);
The images now appear in the menu which I don't want.
The problem page can be seen here.
test.php
Any help much appreciated
Clive
neilo
Hi Clive,
I'm not sure that I understand what you want to do with the image, - do you just want to remove it as a bullet point?
If so, you would just need to remove the ul rule:
ul {
from the end of your /css/haloeffect2.css stylesheet. You can remove it entirely, as it is already defined in your menu.css stylesheet. If this is not what you menat, could you post back with more detail?
cheers
