Update page with DA and SHA1 password if password field empty leave old pass
Thread begun 1/30/2011 11:18 am by Miguel | Last modified 7/13/2011 9:11 am by Jason Byrnes | 4600 views | 4 replies |
Miguel
Hello Comunity, some of the things i miss about addt was how easy it was to update users password in an admin enviroment, right now im trying to save a bit of space and less clicks by making the less pages posible, i came into a problem, i used the wizard of data assist to create the admin section to manage users registered to a site, then applied css form builder to insert and update page, now i always use password encryption in this case i have the sha1 setup nice but on the update page created by data assist, how can i update a user if i dont add anything to the password field to avoid it inserting a null value, on other sites i just make the same but leave pssword field out of the dataassist manager and then create a page just for updating the password.
Is there any way to have the old encrypted password inside a hidden field and tell the update behavoir if the "password field is empty" then insert the "hidden field without applying encryption" cause its already encrypted and if not add the password field, i have tried this:
<?php echo (isset($_POST["pass"])?WA_SHA1Encryption($_POST["pass"]):"".$_POST["oldp"].""); ?>
no luck on this yet, how can i acomplish this it would be nice to avoid to make the update profile and admins part without excluding the password and having to do another page just to update the password field?
you're just one step off on this, change:
to;
<?php echo ((isset($_POST["pass"]) && $_POST["pass"] != "")?WA_SHA1Encryption($_POST["pass"]):"".$_POST["oldp"].""); ?>
Miguel
Thank you jason didnt try that i just added 2 more single updates and then made a trigger specially for them :) lol i will try that on my next site :)
dan361748
This is exactly what I want to do - can you guys expand a little more?
Where are you putting this?
and what/where is the validation on?
This code is used in the Data Assist update record behavior, it is the value used for the password column
validation can be added to your forms using the Form Toolkit extension.
Miguel
Commenting back to this thread, Jason i little question, it has worked very good for me but i been consern about security on the websites do you think if i instead have the old password in a hidden field can i call it directly from the database for example
Jasons code
Question code
<?php echo ((isset($_POST["pass"]) && $_POST["pass"] != "")?WA_SHA1Encryption($_POST["pass"]):"".$recordset["xypassword"].""); ?>
im gonna give it a try tonight if it works ill post back
Yes it works!!!
YEs, using the recordset column will also work.
