Cannot set my server
Thread begun 1/29/2011 3:05 am by J7HNW | Last modified 2/01/2011 11:29 am by Jason Byrnes | 3530 views | 5 replies |
J7HNW
I have set up my first Site Sculptor site and now have the site running on my local testing server. I can access the admin pages etc all fine on localhost.
I have therefore FTPd all files to the main server and gone to run the CMS Setup wizard again but have this error
when I hit the site admin/
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in C:\inetpub\vhosts\traintrac.co\httpdocs\WA_Globals\WA_Globals.php on line 40
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in C:\inetpub\vhosts\traintrac.co\httpdocs\WA_Globals\WA_Globals.php on line 61
Warning: Cannot modify header information - headers already sent by (output started at C:\inetpub\vhosts\traintrac.co\httpdocs\WA_Globals\WA_Globals.php:40) in C:\inetpub\vhosts\traintrac.co\httpdocs\WA_SecurityAssist\Helper_PHP.php on line 67
Please can anybody tell me what is wrong here ?
Thank you
J7HNW
OK running locally now
This post has been deleted.
Brad Lawryk
Originally Said By: J7HNW
Most likely cause is that the remote server is running PHP4. Most commercial hosts have a way to run PHP5 - usually by using an .htaccess file.
Brad
J7HNW
Not a php version issue
Hi
My server is running PHP 5.2.6
Please can you advise what else could be wrong here ?
If you have already run the installation on your local host, you should delete the connections folder on the server to allow the installation to run on the server.
J7HNW
Still a problem
Thanks Jason. I have deleted the connections folder but am now getting this
Server Diagnostic Check
ERROR: All of the attributes below need to check out before you can proceed to the next step.
PHP 5.2.6
PHP 5.2.6 is installed.
GD Image Library
GD Image Library [bundled (2.0.34 compatible)] is installed.
File Permissions
Files and directories cannot be created. Verify the Site Sculptor directory has write permissions on your server.
There is no Site Sculptor directory in the list of folders created. I have applied RWE to all other folders so need more info on where this is having an issue. Should it have created a Site Sculptor folder ? It has made sitesculptor_assets / _images _css all of which have full RWE applied
John
The Site Sculptor Folder is referring to the root folder that you have uploaded the site Sculptor pages to.
it is the Site Sculpttor Root folder that needs to have Read Write Access granted.
