Get diagnostic check to move on?
Thread began 1/28/2011 2:42 pm by OldGuy | Last modified 1/31/2011 6:49 am by Jason Byrnes | 1058 views | 1 replies |
OldGuy
When installing PowerGallery on 'localhost', I get the welcome screen and go to the 'diagnostic check' screen, where it shows ALL three items with green checkmarks and says that everything is working okay. However, there is also the 'red' message that says 'ERROR: All of the attributes below need to check out before you can proceed to the next step'? The 'Run Check Again' button just does that same thing? Does not move on.
Where do I go from here? All PHP/MySQL works just fine under 'localhost' with Xampp working fine.
most likely, you do not have cURL enabled in the php.ini.
you will just need to edit the php.ini file:
find:
;extension=php_curl.dll
and remove the semi colon:
then restart the webserver.
