Extra paragraph return in content
Thread begun 1/28/2011 10:37 am by illbe322016 | Last modified 7/19/2011 10:30 am by Jason Byrnes | 5946 views | 10 replies |
illbe322016
Hi, when I copy content from firefox, paste it into my content window and hit update I sometimes get an extra paragraph return before my content starts in a browser (Firefox). Sometimes it appears as it should, other times there is space, I have looked for any stray <p> tags etc. to no avail. Basically the <div> begins, then the include from PCMS then the </div> ends. Has anyone encountered this before?? Am I missing something?
Thanks in advance
Tom
power cms will automatically add a p tag when you insert data. it sounds when you are copying data, it is copying an additional p tag.
to check for this go into source view by clicking the source button in the toolbar.
info72555
Removing the extra paragraph tag when inserting data
I believe I have come across a solution on here some time ago but I can no longer find it. Because of the way I wish to user PowerCMS in my pages I do not want any additional code. Simply deleting it in Source Code does not work because as soon as I click Update it adds it again.
What file do I need to edit to turn off the automatic insertion of the paragraph tag?
I am using Power CMS 2.02 with FCK Editor.
Thank you
Update: I just found this suggestion: Set FCKConfig.FillEmptyBlocks = false ;
I hope this will fix it. If you have a different solution, please post.
cldsk369146
Also need to get rid of auto-paragraph insertion
I am using the CMS Builder and I also need to get rid of the automatic paragraph insertion that the Power CMS does (it changes the format of the content with some of the tags in the html), while I have had no problem deleting the extra "p" tags in the source mode, it is VERY confusing for my clients, could someone please tell me how to get rid of this automatic insertion? Thanks so much!
info72555
My "Fix" did not work :o(
Would someone from the WebAssist team please respond?
Thank you.
cldsk369146
I agree---would love to find a fix for this!
Please respond WebAssist! Thank you so much!
see this post for details on fixing this:
showpost.php?p=88856&postcount=8
cldsk369146
Many thanks---it looked like that did the trick!
you're welcome.
info72555
There is no "ckeditor/config.js" in Power CMS 2.02
It uses FCK as the editor. Do I just add this code to fckconfig.js or is there a different solution?
