CSS form builder and html editor error
Thread begun 1/27/2011 9:05 pm by Miguel | Last modified 2/17/2011 11:41 am by Jason Byrnes | 4346 views | 4 replies |
Miguel
Hello i think i found a very annoying bug on the css form builder 2 when i activate it to use html editor with file managment, already happening to me on 2 sites im building, after making the forms and selecting the field that contains the html editor selection file management then selecting which conection to use and then Allow access to option, if i have 2 diferent tables for example one for users and another one for admin panel, when i go and test the page and hit the icon called "insert image" it popups the image propertie box, in there i click on check on the server and there it throws me this error:
The server didn't reply with a proper XML data. Please check your configuration
i checked and compared to other sites i made with the only difrence that on the sites where it works fine theres only one tables that manages both users and admins and on the sites it doesnt work is where i manage independant tables one for normal users one for admins.
I manage to make one of the sites that had this problem work the thing is that i modify so much the code on the helper_PHP.php and HelperGroupsRulesPHP.php and html editor config.php spent the hole day testing and changing that i dont remeber what change i did made it work, but still i try to apply those files changing the callings for the other sites but still without luck.
Also testing the page i was login as an admin also tested as a user and so on have lost a hole day cause of this bug hope WA can duplicate the bug so it can get fix.
now the normal upload on the third tab of the image propertie box no matter what it never uploads the files i try to upload that way even with the html editor working check error-2.png it stays there stuck until i close that box and does not upload any picture
If there is any work around if these bugs are already known please let me know what to do im very frustrated with them.
I am trying to replicate this problem, but cannot.
Can you give some more details on how the access rules where created to cause the issue?
If I had some specific details to follow for creating access rules that trigger the problem it would be helpful.
Miguel
Ok table for normal users
CREATE TABLE IF NOT EXISTS `UserTD` (
`IDC` int(11) NOT NULL AUTO_INCREMENT,
`userEmail` varchar(150) NOT NULL,
`passD` varchar(150) NOT NULL,
`Nombre` varchar(100) NOT NULL,
`Apellido` varchar(100) NOT NULL,
`Telefono` varchar(30) NOT NULL,
`Celular` varchar(30) DEFAULT NULL,
`Direccion` varchar(300) NOT NULL,
`Cedula` varchar(150) NOT NULL,
`Registrado` timestamp NULL DEFAULT CURRENT_TIMESTAMP,
`Estatus` tinyint(1) DEFAULT '1',
`activacion` varchar(200) DEFAULT NULL,
PRIMARY KEY (`IDC`)
) ENGINE=MyISAM;
CREATE TABLE IF NOT EXISTS `Administratorz` (
`idSuper` int(8) NOT NULL AUTO_INCREMENT,
`email_sup` varchar(150) NOT NULL,
`passd_sup` varchar(150) NOT NULL,
`Nombres_sup` varchar(200) NOT NULL,
`Nivel` tinyint(1) NOT NULL DEFAULT '1',
PRIMARY KEY (`idSuper`)
) ENGINE=MyISAM;
I then apply security assist wizard twice one for the user tables another for the admin table
The admin php are located inside an admin folder
localhost/sitename/adminfolder/
I also followed the how to do the sha1 encrypting everything works well less the html editor the rules right now i romoved the level access have it normal for admins:
Name: Logged in to Admins
Allow selected
Value: <?php echo $_SESSION['idSuper']; ?>
Criteria: <>
Compare to: nothing here empty
Normal users rules
Name: Logged in to clientes
Allow selected
Value: <?php echo $_SESSION['IDC']; ?>
Criteria: <>
Compare to: empty nothing here this one also has:
Allow selected
Value: <?php echo $_SESSION['Estatus']; ?>
Criteria: =
Compare to: 1
On html Editor on Global File Upload Settings:
Enable file managmente: checked
Upload directory: /imagenes/
Advance file mangement: My conecction selected
Security:
Allow access to: Logged in to Admins
Fail redirect: /Entrar.php
Other things i have on my administration page they are with a template and that template i apply Frames work builder with a theme created for the template.
If i remove the advance file managment it works but without all the crop options
I went live already with the promise to solve the issue soon but had no luck yet on a fix have try everything also i notice this is also happening on other sites where i have a template with theme apply to the page those that i dont apply it work, could it be something witht he framework builder?
I also notice when trying to open the image manager on html editor it shows this link on top
browser.php?Type=Image&Connector=http%3A%2F%2Fdomainname.com%2Fwebassist%2Fhtml_editor%2Feditor%2Ffilemanager%2Fconnectors%2Fphp%2Fconnector.php
Miguel
If i upgrade to html editor 3 would this correct the bug?
soundshape
The server didn't reply with a proper XML data. Please check your configuration.
I've duplicated this error on two different sites. The File Management worked when I first deployed the HTML Editors. I didn't change a thing...and some of the editors on some forms throw the same error, while other form with editors, launch the file manager without a problem - on the same site. I have verify the local and server files are identical. I have set FTP permisions to 775.
I upgraded to DataBridge 1.1.0 and was able to get tsome broken forms working again, however; I now will have to update all forms with an HTML Editor for consistency. Thank you so much for wasting my time and creating duplicate work. WebAssists support has been no help. Great job guys!
Do you want us to look into the problem with you?
we certainly are not trying to waste your time, nor create duplicate work, but i'm not sure how we could have helped you with this issue since you have not asked for help until now...
I'll be happy to set up a support incident so we can investigate the problem with you if you like.
