users_EmailPW redirect
Thread begun 1/27/2011 3:34 pm by danielsebas | Last modified 7/31/2012 10:20 pm by Web Designer Troy | 4398 views | 6 replies |
danielsebas
Hi, I am using framework with the Registration Solution Pack, I add the update record from DataAssist and encrypted the password, I didn't used the SecurityAssist mail option but the default form the users_EmailPW (Universal email 1) I edited the session function for the NewPW cookie.
Everything woks fine but when I send the email the page refreshes under the user_EmailPW.php page and I need it to refresh in the index?id=newpass showing the message that the email was sent. I changed the $WAFV_Redirect = $_SERVER["PHP_SELF"]; to $WAFV_Redirect = header('Location: index.php?id=newpass'); and the mail is sent and the page refreshes were it should but it doesn't show the message that the mail was sent.
Here is my code:
// WA Application Builder Update
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $PowerCMSConnection;
$WA_table = "users";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "UserEmail";
$WA_fieldNamesStr = "UserPassword";
$WA_fieldValuesStr = "".WA_SHA1Encryption($_SESSION['NuevoPass']) ."";
$WA_columnTypesStr = "',none,''";
$WA_comparisonStr = "=";
$WA_where_fieldValuesStr = "".((isset($_POST["emailAddress"]))?$_POST["emailAddress"]:"") ."";
$WA_where_columnTypesStr = "',none,''";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_PowerCMSConnection;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_LostPW = "-1";
if (isset($_POST['emailAddress'])) {
$colname_LostPW = (get_magic_quotes_gpc()) ? $_POST['emailAddress'] : addslashes($_POST['emailAddress']);
mysql_select_db($database_PowerCMSConnection, $PowerCMSConnection);
$query_LostPW = sprintf("SELECT * FROM users WHERE UserEmail = %s", GetSQLValueString($colname_LostPW, "text"));
$LostPW = mysql_query($query_LostPW, $PowerCMSConnection) or die(mysql_error());
$row_LostPW = mysql_fetch_assoc($LostPW);
$totalRows_LostPW = mysql_num_rows($LostPW);
if (isset($_POST["Send_x"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_usersEmailPW_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateEM(((isset($_POST["emailAddress"]))?$_POST["emailAddress"]:"") . "",true,1);
$WAFV_Errors .= WAValidateNM($totalRows_LostPW . "",1,100,"",",.",true,2);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"usersEmailPW");
if(isset($_POST["Send_x"])) {
$nuevopass = $_SESSION['NuevoPass'];
$_SESSION["NuevoPass"] = "".WA_RandomPassword(9, true, true, true, "") ."";
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "".((isset($_POST["emailAddress"]))?$_POST["emailAddress"]:"") ."";include("WA_Universal_Email/WAUE_users_EmailPW_1.php");
//Send Mail All Entries
if (""!="") {
header("Location: ");
Instead of the NewPW session variable I am using the name: NuevoPass
In the ecart session I added: $nuevopass = $_SESSION['NuevoPass']; so I can use $nuevopass in the lost_password.php template page to send the unencrypted password in the mail.
Thank you in advance.
that code change is changing the redirect for failed validations. you want to set the redirect ion the Universal Email server behavior.
double click the universal email server behavior and set the go to page to "index.php?id=newpass"
instead of changing the validation failed redirect.
danielsebas
Hi Jason, I have Universal Email 4 installed and the version used in the solution pack is a different version, when I double click in the server behaviors panel the Universal Email option that is installed in the page it shows me the information of the fields, so I only added in the go dialog box the page to refresh, and it refreshes were it should like in the other option if I change manually the code, but what I want is to maintain the default option of the users_EMailPW.php were it appears the message that the email was sent or that the email is not in the records or that it fails to send the mail within the same page.
Thank you in advance for your help
danielsebas
Hi Jason, I accomplished what I wanted without changing the Universal Email code, I just deleted the action="users_EmailPW" from the form.
OK, glad to hear it is working.
Web Designer Troy
$_SERVER['PHP_SELF']; is giving a double path entry
My question has nothing to do with the above issue. But, I need to ask my questions somewhere.
$_SERVER['PHP_SELF']; is giving a double path entry. I seen this issue in the forum before. What is it?
Reproduce code:
echo $_SERVER['PHP_SELF'];
Expected result:
/testself/testself.php
Actual result:
/testself/testself.php/testself.php
Web Designer Troy
I found the solution
In my php5.ini file, I needed to set:
cgi.fix_pathinfo = 1
to
cgi.fix_pathinfo = 0
