How Many File Uploads Per Page
Thread begun 1/27/2011 1:55 pm by dlovas275157 | Last modified 1/31/2011 2:40 pm by Jason Byrnes | 5226 views | 12 replies |
dlovas275157
Is there a limit to the amount of File Upload server behaviors one can use on a insert or update form?
My form has approx 30-40. They seem to start failing after the 20th upload behavior. Any file upload after the 20th does not work. The file is not uploaded nor is the the filename written to the database. Code is identical for all 30-40 behaviors.
Attached is my code.
I'm using the latest extensions. CSS Form Builder 2.0
Dani Chankhour
Yes, there is a limit that is set on your server.
Can you create a page and add this line of code:
<?php phpinfo(); ?>
And preview the page on your server. This will display information about your server.
Look for this setting:
max_file_uploads
This should tell you if you exceeded the limit that is set on your server.
dlovas275157
Dani,
max_file_uploads is set to 20, and my shared host cannot adjust it. Hosting company tells me it cannot be over-ridden by ini set code either.
Does this sound correct, or do you know of any other solutions.
Thanks.
Dani Chankhour
Unfortunately i don't because usually it is either something the hosting provider can change or you could use ini to set it. You might have to split the form into two pages.
dlovas275157
Dani,
I am trying as you recommended - to split the insert.php form into 2 forms. But I am having trouble with this.
InsertA.php then redirects upon insert to insertB.php. Problem - when I submit insertB.php, it just reloads the page instead of going to the redirect page (detail.php)
Question - should the second form actually be a update page (not an insert page)? And is there some special way to handle the redirects? I need help with the redirects and if they require a .php?id=.... type of link.
Any help is appreciated. THanks - attached is my code.
dlovas275157
Here are screenshots of my Insert Record Server Behaviors if they help troubleshoot.
Thanks again.
yes, the second form should be an update, not an insert.
In reality, splitting the form like this wont fix the issue you are having, with the form split like this, you will still run into the max upload file size limit when uploading since you still have 9 file uploads happening at the same time.
that is the hearty of the issue, having 9 file uploads at the same time.
You would need to create a main insert form, then create a second file upload form that will upload one file at a time and update the database with the new file name. This is going to require hand coding to determine which column the file name should be stored in and we will not be able to offer support for this part.
dlovas275157
Jason,
I have not had issues with this in the past on my host and 9 uploads is far below the 20 max, so I am proceeding with the 2 part insert. I just need help on how to redirect from the initial insert.php (part 1) to the insert/update.php (part 2).
How do I code the redirect on the first insert page to get to the second part (insert/update)?
(I may be wrong, but have built this way in the past without issue)
It is not a 2 part insert, it is an insert, then update operation.
if you do it as a 2 part insert, you end up with 2 separate records.
on the second page, you need to use an update behavior to update the record that was created on the first page.
when a redirect is not working, it means that there is a php error occurring. add the following code to line one of the page to turn error reporting on:
error_reporting
(E_ALL);
dlovas275157
Jason,
No errors are shown when I use the error reporting script.
I have insert.php set to redirect to update2.php (which contains the second half of the uploads).
When I submit insert.php it redirects successfully to update2.php BUT it says "no record found"
