Problem with images not showing, has wrong path
Thread begun 1/26/2011 5:41 pm by gerlinda89667 | Last modified 1/27/2011 3:38 pm by Dani Chankhour | 4307 views | 9 replies |
gerlinda89667
I am having a problem with images not showing. When I view the source it shows the wrong path. This is an add-on domain within another domain. It names the folder that the domain is using when it calls the images, which of course there is no such folder in the domain. gallery.php
I tried the other global file from the sticky post, but it didn't do anything either. Could you help please?
thank you,
Gerlinda
neilo
Hi Gerlinda ,
On your remote server, what is the exact path to your /galleries/ribbon_fullsize/index.php page?
internationalragdollcongress.org/ ? ? ? /galleries/ribbon_fullsize/index.php page?
Also, have you uploaded all of the files and folders to your remote site?
gerlinda89667
Yes, all files are uploaded. Here is the full path.
index.php
Thank you,
Gerlinda
Dani Chankhour
So does the irc-site folder exists on your server?
gerlinda89667
Yes, it is the folder that the domain is in. But shouldn't be referenced as a folder in the domain. In other words, the folder irc_site is the folder that is the domain. But this folder is an add-on domain on another domain. It resides within the main domain.
Right now it is calling the images from: a01_62c.jpg as if the irc_site is a folder in the domain, but it is actually the domain folder.
I don't know if that makes sense?
It is referencing the js files just fine: "/galleries/galleries/ribbon_fullsize/js/gallery.js
Thank you,
Gerlinda
Dani Chankhour
OK, try adding this line of code:
$WAGLOBAL_Root_URL = str_replace('irc_site', '', $WAGLOBAL_Root_URL);
to the global.php file in the galleries folder under line 12.
gerlinda89667
Added the line, but no change. Image still not showing..
Any other ideas? Is there a way to make it not put in the full url when referencing images, like it does for js files, it doesn't use the full url.
Thank you,
Gerlinda
Dani Chankhour
I have opened a support ticket to further assist you with issue:
gerlinda89667
Appreciated, thank you!
Gerlinda
Dani Chankhour
If you could replay back to the support ticket i should be able to assist you.
