Checkbox vale not returning in update form
Thread begun 1/25/2011 3:40 pm by Paul | Last modified 1/31/2011 7:16 am by Jason Byrnes | 2971 views | 3 replies |
PaulBeta Tester
I have created a registration set using SA 1.1.9.
The reg form includes a checkbox where if selected places a 1 in my SQL table - all good.
When logged in using the reg credentials, I open the update page, all the value are returned for edit, except however the checkbox value.
If i change any of the values and update they save, except however the checkbox value does not save.
Any ideas?
Here is the checkbox code
<td align="left" valign="middle"><input type="checkbox" name="alerts" id="alerts" value="<?php echo(str_replace('"', '&quot;', $row_WAATKrrregister['alerts'])); ?>"/></td>
Thanks, Paul
hard code the checkbox value to 1. Then in the property inspector, click the Dynamic button, click the lightning bolt next to check if and select the recordset column, and enter 1 for the equal to box.
PaulBeta Tester
Perfect. Thankyou.
you're welcome.
