Conditions in Shipping
Thread begun 1/25/2011 10:02 am by JohnPicton | Last modified 1/28/2011 6:47 am by Jason Byrnes | 2020 views | 3 replies |
JohnPicton
I'd like to add a condition in the shipping field of eCart which applies a charge if text appears in a session variable.
This needs to work with a postcode - for example if the session variable 'postcode' contains the text AB12 then the p&p charge of x will apply. I need this to work so that if the postcode is 'AB12 3CD' or 'AB12 4EF' is entered then the charge still applies as the text AB12 is included.
So I guess what I'm saying is that rather than be an 'equals' it needs to be an 'includes'.
Is this do-able?
in the trigger for the shipping rule, add a custom condition using the following code:
strpos($_SESSION['postcode'], 'AB12') !== false
JohnPicton
Perfect thank you - I'll give it a go!
you're welcome
