Discount on Quantity of an Item
Thread begun 1/25/2011 9:43 am by bjgarner241692 | Last modified 1/25/2011 2:03 pm by bjgarner241692 | 5248 views | 13 replies |
bjgarner241692
//eCart Rule
function WAEC_eCart1_cards()  {
  $totalDiscount = 0;
  if (true && ((floatval($this->GetInfo("19", "Quantity")) >= 2))) {
    $totalDiscount += (floatval($this->GetInfo("19", "Quantity")) * 1);//Result
  return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
I cannot figure out why this discount does not work. Code was created by the Discount wizard in the eCart UI.
bjgarner241692
//eCart Rule
function WAEC_eCart1_Shipping()  {
  $totalShipping = 0;
  if (true && (($this->GetTaxableTotal() <= 15.00))) {
    $totalShipping += 6.50;//Result
  return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
This rule does not work either. It results in truncating the Cart display after the quantity field of the first row of items.
bjgarner241692
//eCart Rule
function WAEC_eCart1_GraduatedShipping()  {
  $totalShipping = 0;
  if (true && ((sizeof($this->Items) == 1))) {
    $totalShipping += 8.5;//Result
//eCart Rule
I substituted the shipping rule with the above and this rule works fine.
Both issues seem to be related to the presence of a < or >.
So do I have a syntax issue in these first two rules or is there some code missing?
bjgarner241692
Nope - it is not the < or > symbols affecting my Discount because this rule does not work either. It is just ignored.
//eCart Rule
function WAEC_eCart1_Cards()  {
  $totalDiscount = 0;
  if (true && (($this->InCart("19") == true))) {
    $totalDiscount += 10;//Result
//eCart Rule
So, do we have another example of code not being placed by the eCart behaviour?
I'm simply filling out forms here and these are not complicated rules so there is not much that I can do wrong.
the issue with the second rule is most likely that you have selected the option to include shipping in the tax.
If you include shipping in the tax, you cannot use taxable total in the shipping rule, this creates an endless loop where the tax is recalculated because shipping has changed, then the shipping has to be recalculated, because the tax has changed etc....
the one constant with the other rules is that you are testing for an item with an ID of 19
Create a new php page and add a new cart display manager to it. On the second page of the display manager wizard, you can select columns to include in the cart display, add the ID column. this way you can see what ID value is stored in the cart.
Send me a link to your store including this new cart page so i can test it.
bjgarner241692
My Apologies Jason,
The issue is not with WA.
This is very bizarre but when I add the item with ID 19, it is identified in the cart as ID 23
5 is 9
13 is 17
I have no idea how that is happening but I'm looking at PHPMyAdmin and the ID of the product is 19. When I view the product detail it is 19, but when I added the ID column to the the card display it says ID #23.
Truly bizarre.
As a point of interest if anyone knows how this could happen, I'm all ears ....
sounds like the add to cart button is set to use a different column than the primary key column for the eCart ID column.
bjgarner241692
you would think so but:
<input type="hidden" name="eCart1_1_ID_Add" value="<?php echo $row_product["ID"]; ?>" />
column names:
id
name
description
price
category
Only ID and Price are numbers. Everything else is a text field.
No worries, it works now and there is only one item where I need to utilize the ID# so it will be fine.
that's only showing a small part of the puzzle. I would need to see the add to cart code as well to be able to see the full picture.
bjgarner241692
If you insist:
$param_product
"-1";
if (isset(
$_GET["ID"])) {
$param_product = (get_magic_quotes_gpc()) ? $_GET["ID"] : addslashes($_GET["ID"]);
mysql_select_db($database_constring$constring);
$query_product sprintf("SELECT Name,Description,Picture,Extra,prod_pricing.pricelevel,prod_pricing.price, prod_pricing.ID FROM life_prods INNER JOIN prod_pricing ON life_prods.Name = prod_pricing.ProdName WHERE %s = life_prods.ID ORDER BY prod_pricing.Price"GetSQLValueString($param_product"int"));
$product mysql_query($query_product$constring) or die(mysql_error());
$row_product mysql_fetch_assoc($product);
$totalRows_product mysql_num_rows($product);
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"]))     {
$ATC_itemID $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn 0;
$ATC_RedirectAfter "cart.php";
$ATC_RedirectIfIn  "cart.php";
  if (isset(
$totalRows_product) && $totalRows_product 0)     {
$row_product WAEC_findRecordMySQL($product"ID"$ATC_itemID);
    if (
$row_product)     {
$ATC_itemName "".$row_product['Name']  ."";// column binding
$ATC_itemDescription "".$row_product['pricelevel']  ."";// column binding
$ATC_itemWeight floatval("0");// column binding
$ATC_itemQuantity "".$_POST["eCart1_1_Quantity_Add"]  ."";// column binding
$ATC_itemPrice floatval("".$row_product['price']  ."");// column binding
mysql_data_seek($product0);
$ATC_itemQuantity floatval($ATC_itemQuantity);
  if (
is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0)     {
$eCart1->AddToCart($ATC_AddIfIn$ATC_RedirectIfIn$ATC_itemID$ATC_itemName$ATC_itemDescription$ATC_itemWeight$ATC_itemQuantity$ATC_itemPrice);
    if (
$ATC_RedirectAfter != "" && $eCart1->redirStr == "")     {
$eCart1->redirStr $ATC_RedirectAfter;
    if (isset(
$_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "")  {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
    else  {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
<form name="eCart1_1_ATC_<?php echo $row_product["ID"]; ?>" method="POST"  action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>">
                        <input type="text" name="eCart1_1_Quantity_Add" value="1" size="4" >
                        <input type="submit" class="eC_FormButton" value="Add to Cart" name="eCart1_1_ATC">
                        </form>
