Using GET instead of POST
Thread begun 1/25/2011 8:35 am by jcrockett300688 | Last modified 4/10/2012 4:03 pm by Cactus Gary | 2392 views | 4 replies |
jcrockett300688
After a form is submitted, I need to pass certain form data to a thank-you page so I can process it into a printable user name tag. I tried setting the form to GET instead of POST but that breaks everything (no form data is being sent and page isn't redirected). It needs to be simple (no database). Is this possible with UE?
you should leave it to use the post instead of get.
add the following code at line 1 of the page:
if(!session_id()) session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
$_SESSION[$key] = $val;
this will store the posted elements into session variables of the same name.
On the thank you page, instead of echoing the post:
<?php echo((isset($_POST["textfield"]))?$_POST["textfield"]:"") ?>
use the session:
<?php echo((isset($_SESSION["textfield"]))?$_SESSION["textfield"]:"") ?>
jcrockett300688
Works...with small addition
Didn't work until the top of the thank-you page included:
session_start();
Thanks!
glad to hear it is working.
Cactus Gary
Placing the code at the top of the page didn't work for me. I modified the code further down the page and it works properly.
Original Universal Email Code:
if (!isset($_SESSION))session_start();
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="mail"
Modified Code:
foreach($_POST as $key => $val) {
