Error when navigating from the results to view, update & insert
When I click on either the view, update or insert options from the results page I get the following error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'range FROM Handsets WHERE handset_ID = 12 OR ( -1= 12 AND handset_ID= -1)' at line 1
Can anyone help me with this?
