coupon variable
Thread begun 1/24/2011 7:36 pm by info13749 | Last modified 1/25/2011 12:59 pm by Jason Byrnes | 2873 views | 5 replies |
info13749
coupon variable
Hi Guys,
Converting over from asp to php, in my asp carts I've a discount rule using a session variable
SESSION("voucherDisc")/100
When I use $_SESSION["voucherDisc"]/100 in php I get an error Parse error: syntax error, unexpected ';' in
I'd greatly appreciate it if someone can tell me what my php syntax error is
Cheers
Norman
try using single quotes:
$_SESSION['voucherDisc']/100
if that does fix the problem, I will need to see the entire error message including line numbers and a copy of the eCart object file.
info13749
Database Driven Coupon
Hi Jason
Tried the single quote earlier, the response is . . .
Notice: Undefined index: voucherDisc in C:\Inetpub\jadremtoysau\WA_eCart\jadremtoys_PHP.php on line 89
Attached is cart file
The session object 'voucherDisc' picks up a value from our database, at the moment for testing purposes its just set at a static value in the code
Cheers
Norman
add a trigger to the discount rule:
based on session variable existence
to check if the session is set, that error happens when the session does not exist.
info13749
Thanks Jason,
Set a trigger, works fine
Cheers
Norman
glad to hear it is working.
