Email custom URL to validate registation
Thread began 1/24/2011 1:39 pm by info22862 | Last modified 1/24/2011 2:18 pm by Jason Byrnes | 1177 views | 1 replies |
info22862
I have a few questions regarding the security assist registration.
#1 The pre-build solution for Registration and login is exactly what we need. Specifically the feature where a custom URL is sent to the registrant's email address which they need to click on in order to validate their registation.
Is this feature NOT in Security Assist already?
If so where?
#2 Is it possible to have the username = email address, and password is variable. However when the user logs in, we are able to assign the uniqueid as the username, as opposed to the email address?
#3 Does SA use any server side security measures besides form validation and encryption?
Need to decide if purchasing the pre-built solution makes sense, since we already own all the tools that are necessary to create it?
I'm glad to see that this forum is very active.
Thanks in advance for your help.
no, that is not built directly into security assist, but it can be accomplished using security assist and Universal Email:
showthread.php?p=65008
the unique ID is assigned from the users table Primary key column. You can of course store the username, and or email address column in a session variable to display that information if you like, but the unique identifier for the user should be the primary key value.
You would need to use form toolkit to add any additional server side validation to the security assist registration or login form.
