add new menu item to main nav
Thread begun 1/24/2011 12:15 pm by segalmedia367166 | Last modified 4/07/2011 12:24 pm by Jason Byrnes | 3056 views | 4 replies |
segalmedia367166
I want one more menu tab on my main menu. Is there a way to do this via admin? If not, which file controls the main menu so that I can manually add one more (or do you advise against this?).
Thanks,
Lisa
the menu is created in this file:
webassist/plugins/main_menu/menu.php
you may need to edit some css to get any new buttons to fit.
segalmedia367166
thanks
Thanks for the help
Andre.M
css menu writer edit?
where would i go to edit the menu with the css menu writer extension?
the power store 4 menus are not editable using CSS Menu Writer, this is not supported.
