DFP file upload suddenly doesn't work
Thread begun 1/24/2011 9:39 am by kbettenc296716 | Last modified 1/26/2011 9:46 am by Jason Byrnes | 3972 views | 5 replies |
kbettenc296716
I successfully uploaded images for this client on 1/20. I went back to upload more today and neither Update or Insert works, a record is written to the database but not the image/thumbnail filenames. The files are not uploaded either. I restored the php files that were used on the 20th, (dated 1/12) and they still didn't work. I have attached the set of files.
lets start with troubleshooting the insert page, then move on to the update.
in the insert page, find the following lie:
$WA_redirectURL = "images_Detail.php";
and change it to:
$WA_redirectURL = "";
then add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
and add this code befoer the closing </body> tag:
<?php echo WA_DFP_AllUploadsDebug(); ?>
post back the results after testing the upload.
kbettenc296716
I have attached the HelperPHP file
Warning: mkdir() [function.mkdir]: Invalid argument in \\nawinfs03\home\users\web\b1947\rh.jbartist\WA_DigitalFilePro\HelperPHP.php on line 30
Warning: mkdir() [function.mkdir]: No such file or directory in \\nawinfs03\home\users\web\b1947\rh.jbartist\WA_DigitalFilePro\HelperPHP.php on line 30
Warning: move_uploaded_file(\Images\Projects\8d45039bc187ca208faa8982325e23cd_tmp.jpg) [function.move-uploaded-file]: failed to open stream: No such file or directory in \\nawinfs03\home\users\web\b1947\rh.jbartist\WA_DigitalFilePro\HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move 'C:\PHP\uploadtemp\php9F90.tmp' to '\Images\Projects\8d45039bc187ca208faa8982325e23cd_tmp.jpg' in \\nawinfs03\home\users\web\b1947\rh.jbartist\WA_DigitalFilePro\HelperPHP.php on line 96
Warning: copy(\Images\Projects\8d45039bc187ca208faa8982325e23cd_tmp.jpg) [function.copy]: failed to open stream: No such file or directory in \\nawinfs03\home\users\web\b1947\rh.jbartist\WA_DigitalFilePro\HelperPHP.php on line 98
the error is saying that the upload directory Images/Projects/ does not exist on the server and cannot be created.
make sure that the folder Images/Projects/ is created on the server and that it allows read write access for all users.
kbettenc296716
Hmmm
Images/Projects/ is on the remote server, always has been. The images uploaded on the 20th are there in that folder. See attached view. I don't understand how this could have changed in 4 days? The only thing done on the site was to create a Wordpress blog in another folder. The permissions are the same as for another client where I successfully uploaded an image today using DFP (at the same ISP). see attached.
