$WA_redirectURL =
Thread begun 1/23/2011 5:14 pm by davidp420108 | Last modified 4/08/2016 11:34 am by Ray Borduin | 5118 views | 9 replies |
davidp420108
$WA_redirectURL =
Is this the place that tells the submitted form where to go? I have changed it to a different url and it doesn't seem to matter. it still goes to the one that was created by WA.
in this case it goes to a detail page created by DA, but i would like to reroute it.
David
davidp420108
seemed to be a cache thing. it works now. what a wasste of time that one was
thanks
mleonard321976
How did you solve this?
Can you say how you solved this problem?
No matter what I do. I cannot get the page to redirect to a new page. It doesn't move from the current page.
If the redirect is not working, it could be a php error occurring preventing the header function from redirecting.
Add the following at link one of your page to turn error reporting on:
error_reporting
(E_ALL);
be careful not to leave any blank space or blank lines between this code and the existing code on the page or you will trigger other errors. report back any errors you see and a copy of the page in a zip archive so we can examine the issue,
mleonard321976
tried that
Hi, thanks for replying..
I added the error reporting section but got no errors..
My main problem is that that page doesn't go aywhere when the form is submitted.
I tried changed header("Location: ".$WA_redirectURL); to header("Location: "."page.php"); but it give me an error, says headers already sent.
Send a copy of your page please in a zip archive.
Yvonne
Redirect not working either.
error_reporting
(E_ALL);
I added the error report code but didn't get an error either. After the form submits is stays on the page. It does add the info the db.
It could be a blank line in one of the include files. I'd need FTP access to debug it fully.
Yvonne
Credentials
See Private area
Yvonne
Resolution
In the Universal Email server behavior I changed the redirect there instead of in the Insert Record Behavior. It worked on my other page /capture-rep-page.php
