How to auto include date in Insert behavior
Thread begun 1/22/2011 8:35 am by Sally | Last modified 1/24/2011 11:10 am by Jason Byrnes | 2056 views | 3 replies |
Sally
I have a form that use the sb Insert to put the fields in a db. I would like to include the date as well, but don't want to ask them to enter that. I noticed that the email template has the date on it, and I'm wondering how can I get that to be included in my Insert behavior?
Thank you.
In the database table, set the default value for your date column to:
CURRENT_TIMESTAMP
This way todays timestamp will be used by default when a record is inserted.
do not bind the date column to anything ion the insert record behavior.
Sally
Thanks. I wondered later if I should probably do it in the db.
you're welcome.
