Getting email To to include email field in form
Thread begun 1/22/2011 8:17 am by Sally | Last modified 1/25/2011 6:51 am by Jason Byrnes | 5561 views | 13 replies |
Sally
I have a emailed form where a user fills in a field with an email address which is supposed to be included in the To recipient list. This seems like it should be easy, but I'm having a hard time with it. The code currently is
$RecipArray[$CurIndex ][] = "".((isset($_POST["GuestEmail"]))?$_POST["GuestEmail"]:"") ."";
Can anyone tell me where I'm going wrong?
Thanks.
the code looks correct. I will need a copy of the entire page though to see the code in context.
Sally
Thanks for looking at it.
Is the email going to the other recipients, just not the Guest Email address?
If the email is going out to the other recipients, you will need to contact the host to have them look into smtp server error logs to see why the email is not being relayed to the guest email address.
Sally
Hmm, this is curious.
I // out the two static email addresses and tested it and it worked - I got both my copy as the sender, and to the guest's email I provided.
So I added the static addresses back, but after
$RecipArray[$CurIndex ][] = "".$row_rs_session['txtemail'] ."";
and I got the one for me (as the sender) but not the one to the guest's email address. I've asked the static recipients to let me know if they got them, but they aren't by a computer so I don't know.
I do know the two static email addresses are valid as I've tested other forms that go to them and they've gotten them. Plus I don't think the form would fail just because of an invalid email address.
Just for grins, I tested a plain old Contact form and it came through to my static email address fine.
I've attached the support files in case you can spot any reason for this.
one thing to try is to go to the Universal Email behavior and set the Goto page to be blank.
then edit the webassist/email/mail_php.php file.
find the following code:
if ( $mailObj)  {
        $_SESSION[$mailRef."_Status"] = "Success";
        $_SESSION[$mailRef."_Log"] .=  "Success <br>\n";
    else  {
        $_SESSION[$mailRef."_Status"] = "Failure";
        $_SESSION[$mailRef."_Log"] .=  $_SESSION[$mailRef."_Error"]. " - Failure <br>\n";
    return $mailObj;
and change it to:
if ( $mailObj)  {
    else  {
        echo($mailTo."-"$_SESSION[$mailRef."_Status"]."<br />");
    return $mailObj;
this will write to the screen each to address being used and it's status for passing the message to the SMTP server, post this information back.
Sally
Now when I try and load the page I get this error:
Parse error: syntax error, unexpected T_VARIABLE in /data/25/2/98/45/2424045/user/2657060/htdocs/test/webassist/email/mail_php.php on line 299
line 299 says
sorry, had a syntax error, that line should be:
echo($mailTo."-".$_SESSION[$mailRef."_Status"]."<br />");
Sally
It said all were sent successfully, and I did get my two. Again, I don't know about the two static email addresses yet, but this appears to be working.
But I didn't change anything except remove the confirmation page and put in this echo code, so now I'm wondering why?
if it is reporting success, that means that the email has been handed over to the servers SMTP server.
At this point, it is up t o the smtp server to relay the email messages to the recipients, i the recipients are not getting the emails, then you need to contact the host to have them look into the smtp server error logs to see why the emails are not being relayed.
