insert photo on with new record
Thread begun 1/20/2011 6:43 pm by davidp420108 | Last modified 1/21/2011 10:09 am by Jason Byrnes | 3636 views | 9 replies |
davidp420108
All my other problems have stemmed form this. a new thread seemed correct since i may be able to ask a clear question now.
I want to upload a picture that goes to a dynamically generated folder. the folder name is the same as the record id that is autogenerated.
how do i get the new id number to create the folder prior to inserting an image into it?
I am stumped...the only thing i can seem to find is using some version of GETLAST, but everything I read says this can cause problems on a mutliuser environment.
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "./".$_SESSION['Dealer_Name'] ."/images/".$_POST["Inventory_ID"] ."/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
Inventory_ID is the the unique auto incrementing number i want to use for the new folder.
can this be done simultaneously(in the eyes if the user)?
Thanks,
David
This is a bit of a quandary. You cant reliably know the ID that will be used for the record untill the insert has taken place.
I think to do this you will need to use a three step process:
Insert Record
Upload Image
Update record
In the data assist insert behavior, there is a setting called Store As, this stores the ID of the record that was inserted into a session variable.
You could insert the record with all of the other information from the form, use the Session Created by the Insert Record behavior in the File upload path, then Update the record to store the uploaded file name.
Make sure that the Insert record behavior does not have a redirect set. you will probably need to rearrange the code for the behaviors to get into the right order and you'll also want to use the Cookies Toolkit unset session behavior to clear the session after the update has taken place.
davidp420108
am understanding that this can be done on one page? it just needs to have the proper order of code?
Yes, it can all be done on one page, just as long as the code is in the correct order:
insert
upload
update
davidp420108
almost there...just a little more help please.
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $Auto_Sales;
$WA_table = "inventory_tbl";
$WA_sessionName = "WADA_Insert_inventory_tbl";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "Inventory_ID";
$WA_fieldNamesStr = "Dealer_Name|Price|Make|Model|Year|Engine|Drivetrain|Transmission|Mileage|Ext_Color|Int_Color|Body_Style|VIN|Stock_Number|Description|Date_Online|Expires|pwr_windows|pwr_locks|rear_slider|DVD|3rd_seat|premium_sound|leather|bed_liner|Dealer_TBL_Dealer_ID|Status|City|Contact_Phone";
$WA_fieldValuesStr = "".((isset($_POST["Dealer_Name"]))?$_POST["Dealer_Name"]:"") ."" . "|" . "".((isset($_POST["Price"]))?$_POST["Price"]:"") ."" . "|" . "".((isset($_POST["Make"]))?$_POST["Make"]:"") ."" . "|" . "".((isset($_POST["Model"]))?$_POST["Model"]:"") ."" . "|" . "".((isset($_POST["Year"]))?$_POST["Year"]:"") ."" . "|" . "".((isset($_POST["Engine"]))?$_POST["Engine"]:"") ."" . "|" . "".((isset($_POST["Drivetrain"]))?$_POST["Drivetrain"]:"") ."" . "|" . "".((isset($_POST["Transmission"]))?$_POST["Transmission"]:"") ."" . "|" . "".((isset($_POST["Mileage"]))?$_POST["Mileage"]:"") ."" . "|" . "".((isset($_POST["Ext_Color"]))?$_POST["Ext_Color"]:"") ."" . "|" . "".((isset($_POST["Int_Color"]))?$_POST["Int_Color"]:"") ."" . "|" . "".((isset($_POST["Body_Style"]))?$_POST["Body_Style"]:"") ."" . "|" . "".((isset($_POST["VIN"]))?$_POST["VIN"]:"") ."" . "|" . "".((isset($_POST["Stock_Number"]))?$_POST["Stock_Number"]:"") ."" . "|" . "".((isset($_POST["Description"]))?$_POST["Description"]:"") ."" . "|" . "".((isset($_POST["Date_Online"]))?$_POST["Date_Online"]:"") ."" . "|" . "".((isset($_POST["Expires"]))?$_POST["Expires"]:"") ."" . "|" . "".((isset($_POST["pwr_windows"]))?$_POST["pwr_windows"]:"") ."" . "|" . "".((isset($_POST["pwr_locks"]))?$_POST["pwr_locks"]:"") ."" . "|" . "".((isset($_POST["rear_slider"]))?$_POST["rear_slider"]:"") ."" . "|" . "".((isset($_POST["DVD"]))?$_POST["DVD"]:"") ."" . "|" . "".((isset($_POST["3rd_seat"]))?$_POST["3rd_seat"]:"") ."" . "|" . "".((isset($_POST["premium_sound"]))?$_POST["premium_sound"]:"") ."" . "|" . "".((isset($_POST["leather"]))?$_POST["leather"]:"") ."" . "|" . "".((isset($_POST["bed_liner"]))?$_POST["bed_liner"]:"") ."" . "|" . "".((isset($_POST["Dealer_TBL_Dealer_ID"]))?$_POST["Dealer_TBL_Dealer_ID"]:"") ."" . "|" . "".((isset($_POST["Status"]))?$_POST["Status"]:"") ."" . "|" . "".((isset($_POST["City"]))?$_POST["City"]:"") ."" . "|" . "".((isset($_POST["Contact_Phone"]))?$_POST["Contact_Phone"]:"") ."";
$WA_columnTypesStr = "',none,''|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,NULL|',none,''|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_Auto_Sales;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "Photo_1_File", "0", "", "JPG:80", $WA_UploadResult1_Params);
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
'UploadFolder' => "./".$_SESSION['Dealer_Name'] ."/images/".$_POST["WADA_Insert_inventory_tbl"] ."/",
// WA_UploadResult1_1 End
it is not seeing the image name now. folder is creating but image not being saved.
the session created by the insert record behavior is "WADA_Insert_inventory_tbl":
in the upload behavior, you dont set the image name using the post in the upload folder:
should be:
'UploadFolder' => "./".$_SESSION['Dealer_Name']  ."/images/".$_SESSION["WADA_Insert_inventory_tbl"]  ."/",
davidp420108
i made the changes. but the file is still not being saved. it saved the file when it was in the order:
upload
insert
but changing it to the order
insert
upload
update
has caused it to drop the filename. i do not see that it is saving the .jpg anywhere on the site at this time.
is a section of code "out of order"?
Thanks Jason
yeah the upload code is out of order, the parameters should be first;
if(isset(
WA_DFP_UploadFiles("WA_UploadResult1""Photo_1_File""0""""JPG:80"$WA_UploadResult1_Params);
also make sure not to leave spaces between the code blocks.
davidp420108
thanks...works great now.
Your WA staff is really helpful. thanks again
David
you're welcome.
