embedding Thumbnsil image in Poppup
Thread begun 1/20/2011 10:50 am by holt3937911 | Last modified 1/20/2011 12:30 pm by Jason Byrnes | 2001 views | 3 replies |
holt3937911
I'm needing to include a small thumbnail image in the Pro Maps pop-up Info window that occurs when you hover your mouse over a marker. When using the custom settings I'm able to include a link in the window using the <a> tags....and would expect to be able to use <img> tags...but the space for the image is created...e.g. the popup window size is increased.... but the image is always blank (white in color).
Any suggestions on how to insert an image in the pop-up?
like you say, adding an image tag should be all that is needed. send a link where i can see the problem to look into the cause.
holt3937911
Image to the left side
THanks.....after creating a simpler page to show you I got it working. Hmmmm THanks,
Is there a way to have the image on the left side...and the other text to the right....I tried using a HTML table with <Table> <tr> and <td> tags...but it didn't seem to work....could have been related to my other problems.
a table should do the trick. Again, i would need to see the problem to troubleshoot the cause.
