Unable to log in.
Thread begun 1/20/2011 7:47 am by gpaul | Last modified 1/21/2011 8:33 am by Jason Byrnes | 7596 views | 15 replies |
gpaul
Unable to log in.
I have created a digital download file, following the tutorial provided on the site. I have created the databases using Wa_Commerce_xxx.sql, inserted my information to be able to log in, created download_center.php, set up Security Assist.
I am unable to log in. After some failures, I set log in fail to the download_center.php just to test the DL, and I get the error message that Widows Could not Display the page. All files are on the testing server. So it would seem my issue is with Security Assist.
I'm sorry, I am just not sure what code to post for this, if someone could let me know.
Thank you
Gary
can you send me your login page, the download page and the WA_SecurityAssist/HelperGroupRules_php.php page in a zip archive so i can see how it is set up.
gpaul
Thank you, find attached the files.
Gary
the login looks OK. lets double check that the testing server is properly set for sessions. use the session test page form the following thread to test the server:
showpost.php?p=23826&postcount=2
gpaul
This is what I got
This link does not contain the URL variable, so it will not set the session variable again, but the session variables value should not be changed.
Session Test = test
(When the page is first loaded, the session variable test will = NULL, when you click the first link, the session variable test will be set to test. Clicking the second link will only reload the page, the session variable test should still equal test, if it equals NULL, your server has a problem with session management.
Session ID = 9aq0et0bjugbqrqr7gqetm4fd3
(NOTE: if sessions are working correctly, the session ID should not change.)
what do you get when clicking the second link, that is the key
gpaul
That was it, there was not change... I'll click first and paste, then second and paste
First
Session Test = test
Second
Session Test = test
just to double check, you have registered a user through the registration page, right?
add the following code at line 1 of the login page and the download page to turn on error reporting:
error_reporting
(E_ALL);
gpaul
[QUOTE=Jason Byrnes;87768]just to double check, you have registered a user through the registration page, right?
I beleive so, I had created the log in page a while back, had entered my information. I did have to manully enter my username directly into the database because the form did not have an input for it.
The error message on the download_center page is
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\xampplite\htdocs\johnfin\download_center.php:5) in C:\xampplite\htdocs\johnfin\WA_SecurityAssist\Helper_PHP.php on line 5
Warning: Cannot modify header information - headers already sent by (output started at C:\xampplite\htdocs\johnfin\download_center.php:5) in C:\xampplite\htdocs\johnfin\WA_SecurityAssist\Helper_PHP.php on line 67
For the log in, the page displays, however there is this error message
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\xampplite\htdocs\johnfin\cust_login_LogIn.php:4) in C:\xampplite\htdocs\johnfin\cust_login_LogIn.php on line 6
the error messages are showing because you left blank space between php code blocks when you pasted the error code I gave, make sure there are no blank lines or spaces between the error code and the next php code block.
can you send a backup of the users table from your database please.
