Data Assist error on Finish
Thread begun 1/20/2011 3:21 am by sales342071 | Last modified 10/18/2011 6:42 am by Jason Byrnes | 5685 views | 7 replies |
sales342071
I have recently reinstalled Data Assist and have gone through the tutorial to refresh my memory. However, every time I click 'Finish' at the end of the Data Assist wizard, I get an error message from Macromedia Dreamweaver saying:
"While executing onClick in WA_AppBuilder.htm, a JavaScript error occurred. <OK>"
This message comes up twice and the wizard does not close. When I click <cancel> to close the wizard, it crashes Dreamweaver.
I have uninstalled, downloaded the extension again, and reinstalled Data Assist but this recurs every time.
Using Data Assist 2.0.8 on Dreamweaver 8. I have deleted the .dat file and this made the situation worse (DW stopped responding when trying to make the Category field into a Menu item and crashed DW again).
DataAssist 2 does not support Dreamweaver 8. You can see the system requirements for DataAssist here:
system-requirements.php
It is supported on Dreamweaver CS3 and up.
sales342071
Response
Jason,
Many thanks for your response. On the basis of what you said I have upgraded to Adobe CS5 and reinstalled the Data Assist 2.0.8 extension.
Trying the run-through again, this time on clicking finish it just goes straight for the crash of DW without giving any details.
Any more advice, please?
I assume you tried deleting the cache file again?
What is your OS?
Are you using a local testing server? or a remote one? I recommend using a local testing server with data assist.
what is the structure of the database, can you post the create table syntax?
sales342071
Jason
Thanks for your response.
I have looked to delete the cache file again but it doesn't exist. I'm operating on Win 7 (64bit) with an intel i7 2.93GHz processor and 6GB of RAM.
I'm using a local testing server running on XAMPP with MySQL 5.
I'm using one of the eCommerce databases supplied by WebAssist,I've posted the .sql set-up file as a text document.
DAssist goes through the whole process without problem until the Finish button is pressed, at which point it crashes dreamweaver.
Regards
Glenn
goat200487425014
I am having the exact same problem and I went through all of the steps as sales342071. What should I do now?
