PHP warning after update
Thread begun 1/20/2011 1:36 am by lt416410 | Last modified 1/21/2011 6:28 am by Jason Byrnes | 2902 views | 5 replies |
lt416410
I have used Powergalley 1.20 without problems. With a fresh install of v1.21 I received this warning below. What does it mean and how do I fix? Or just disregard. Thanks.
Warning: require_once(images/installed.png) [function.require-once]: failed to open stream: No such file or directory in /home/lougharr/public_html/boatgallery/admin_gallery/global.php on line 34
Fatal error: require_once() [function.require]: Failed opening required 'images/installed.png' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/lougharr/public_html/boatgallery/admin_gallery/global.php on line 34
lt416410
Can't login
The warning noted in my first post of this thread stops any log-in or access to the program.
the error means that the admin_gallery/images/installed.png file cannot be found on the server.
make sure that this file is uploaded to the server.
lt416410
Invalid Image
My copy of "installed.png" is marked "invalid image" and has a date different than the other images in that folder.
lt416410
Invalid image
I removed everything from the site and downloaded a fresh copy of v1.21. Before I uploaded I looked at the files. The copy of "installed.png" is marked "invalid image." Where can I get a valid image? Can I just rename a copy of a valid image of the same size and use that?
Thanks.
the installed.png is not actually an image file.
it is a php file, you will not be able to open it in an image editing program, do not try to open it, just upload it to the server.
