header error
Thread begun 1/19/2011 11:01 pm by kleinermitzen420599 | Last modified 1/20/2011 2:56 pm by Jason Byrnes | 5272 views | 10 replies |
kleinermitzen420599
header error
This code...
// WA eCart Redirect
if ($graceCart->redirStr != "") {
header("Location: ".$graceCart->redirStr);
is receiving this error...
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\graceAndLace\homeGraceStore.php:83) in C:\xampp\htdocs\graceAndLace\homeGraceStore.php on line 117
kleinermitzen420599
What can i do to fix that?
The headers already sent error means that there is output to the page before the header() function or session_start() function is used.
If you exmine the error message closely, the section in pereenthises:
tells you where to look for the output that is causing the problem.
look around line 83 of the homeGraceStore.php page.
Usually the problem will on the line before the error is reporting. In most cases the problem is caused by a blank line between a closing php and opening php tag:
in some cases, it can be caused by a blank space after the closing php tag:
it can also be caused by an html comment between the tags, or a misplaced echo statement.
If you cannot find the cause of the problem, please send a copy of your page in zip archive so i can inspect the code.
kleinermitzen420599
Thank you for all your help! error message is gone, but the checkout button doesn't go anywhere, i will attatch a zip. Just to let you know, i have made a new store to test out what i am doing wrong. so it'll be different than the previous codes i have sent you. Thank you so much!
you have not set an action for the checkout button.
go to window -> Server behaviors.
in the server behaviors list, double click the eCart Checkout button server behavior to set the checkout button redirect.
kleinermitzen420599
Thank you! That works great! except now when i checkout after the form is filled out, it gets an error...
Fatal error: Call to undefined function curl_init() in C:\xampp\htdocs\graceAndLace\WA_eCart\WA_eCart_UPS_PHP.php on line 72
This is the code on line 72...
$WA_UPS_Curl = curl_init();
that error means that the cURL extesnion is not enabled in the php.ini file.
C:\xampp\php\php.ini
find the following line:
;extension=php_curl.dll
change it to:
then restart the Apache server.
kleinermitzen420599
Thank you! That works perfectly! Though this is what i get now...
It brings me to the shipping quote failed page:
This is what it says:
S is not a valid unit of measurement for weight for this shipment
what did you set the weight measure to in the shipping rate lookup behavior on the confirm page, it should be set to LB
kleinermitzen420599
Now its saying LB is not a valid measurement. Is there something in the set-up for the confirm.php page that i missed?
