Data not showing after update
Thread begun 1/18/2011 12:14 pm by jimnpd248092 | Last modified 1/19/2011 1:29 pm by Jason Byrnes | 2965 views | 5 replies |
jimnpd248092
When i update my page the data appears in sql server but the field is blank when I try to update the same record again? When I run my recordset in DW CS3 it also does show the updated data.
make sure that the update record behavior is on the page before the recordset that is used to populate the update form.
jimnpd248092
Update not working
I have the update before the rs. It still does not show the data in certain fields. SQL Sever shows the data.
I have attached my code.
the fields that are not showing:
RECOVERYADDRESS
STARTDATE
ENDDATE
STARTTIME
ENDTIME
DOW
DETASSIGNED
AS COMMENTS
ALL OTHER FIELDS ARE FINE.
can you view source of the page in the browser and send the browser source of the update page please,
jimnpd248092
source
here is the source code from browser
