CSS Form Builder Beta Build 022 Available
Thread begun 1/18/2011 9:56 am by Anna Robinson | Last modified 5/30/2013 7:33 am by Jason Byrnes | 2797 views | 5 replies |
Anna Robinson
Brian - Ray will work with you to make sure we have fixed the issues you reported. Here is the build you should install.
Download Form Builder 022 beta build
Form Builder serial #: h9GBO-38XhE-0yCWC-kFzOo
For anyone else just starting on the beta, here is the information for both:
Download HTML Editor 015 beta build
HTML Editor serial #: hXaPQ-ynhUn-0yESK-fIVLX
Test I would like you to run:
If you have Form Builder 1.x or 2.0.0 installed, uninstall.
Install Form Builder build referenced above.
Use the wizard to create a form and add a HTML Editor form field.
Then on a separate page, add a stand-alone HTML Editor form field, not using the Form Builder wizard, but the HTML Editor access points.
Next:
Install HTML Editor 3 build referenced above.
Use the Form Builder wizard to create a form and add a HTML Editor form field.
Any other tests you want to run would also be appreciated. Thank you for feedback.
anonymous
Thanks Anna. I will get it installed here in just a few minutes and start banging on it to see what I come up with.
Warmest regards,
Brian
anonymous
Hey Ray,
I am still getting the error for "Null Undefined" where the server validations should be.
This time, I made sure to denote what is happening.
I found that the Form Builder beta works fine before installing the HTML Editor 3 beta.
I ran the test a few times without the the new HTML Editor 3 and all the validations work fine.
Only after installing the HTML Editor 3 do I get that issue - which is strange because some of the forms I was creating didn't even have an instance of HTML Editor.
So my guess is that with code in Form Builder that gets updated when HTML Editor 3 is installed, it must also be causing a conflict with other attributes in the Form Builder extension.
Other than that, I can confirm that previews now work great inside the dialog box when you add an HTML Editor instance.
Best regards,
Brian
I think we finally found and fixed that null/undefined error. Please check out the latest build and let us know what you find.
alexlewis010438286
Hi, I've got the CSS FB 2.0.1, When I click the download link you posted i'm prompted with a username/password.. is this the login used when logging into my account on webassist site?
These beta builds are not longer available, they have been replaced by Form Builder 2.0.1 and HTML Editor 3.0.2 and more recently by Design Extender and Data Bridge.
NOTE: This thread is form 2 years ago.
