Validating the whole form..
Thread begun 1/17/2011 8:53 am by Andrew Dodd - ADDIGITAL | Last modified 1/19/2011 6:53 am by Jason Byrnes | 3837 views | 5 replies |
Is it possible to validate the whole of your form using just Forms toolkit Server Validations, or is it just for the captcha?
I can't seem to get client validations from CSS Form Builder to work, so I'm guessing the two don't work together. CSS-FB recognises my form but won't allow to select form elements to validate.
Yes, the server validations can validate the entire form.
the client validations in form Builder should be able to work with Form Toolkit, can you give details on the problem you are having?
Client Side Validations
Hi Jason, thanks for the speedy reply!
The form builder client validations allow me to customise the two error messages (header & footer) and the form is listed. However, once I try to add elements from the form to validate, the drop down menu doesn't work, as shown in the attached screenshot. I've also included the error message I get when I cancel the client side validation wizard.
The live page can be seen at contactus.php
The captcha validation works perfectly.
Cheers
Andrew
Hmm, i think that error may be the same issue from this post:
showpost.php?p=82842&postcount=4
Hi Jason,
Have done this, but the end result is the same.. Any other ideas?
Andrew
