CSS Form Builder Beta Build 021 Available
Thread begun 1/14/2011 12:32 pm by Anna Robinson | Last modified 1/16/2011 6:55 pm by anonymous | 1415 views | 3 replies |
Anna Robinson
Dave and Brian - We have fixed the bugs you reported. Both were fixes in CSS Form Builder so you can download only that build. I would be very appreciative if you would be willing to re-do the quick test cases again.
Download Form Builder 021 beta build
Form Builder serial #: h9GBO-38XhE-0yCWC-kFzOo
For anyone else just starting on the beta, here is the information for both:
Download HTML Editor 015 beta build
HTML Editor serial #: hXaPQ-ynhUn-0yESK-fIVLX
Test I would like you to run:
If you have Form Builder 1.x or 2.0.0 installed, uninstall.
Install Form Builder build referenced above.
Use the wizard to create a form and add a HTML Editor form field.
Then on a separate page, add a stand-alone HTML Editor form field, not using the Form Builder wizard, but the HTML Editor access points.
Next:
Install HTML Editor 3 build referenced above.
Use the Form Builder wizard to create a form and add a HTML Editor form field.
Any other tests you want to run would also be appreciated. Thank you for feedback.
Dave BuchholzBeta Tester
Thanks Anna,
I'll download and give it a whirl over the weekend and report back.
anonymous
Hi Anna,
I ran all the tests again and experienced the same minor issue with the preview after installing HTML Editor 3.
I gave a full detailed report in the other thread where Dave had asked for me to report the contents of the preview file.
Best regards,
Brian
anonymous
In addition to the previously reported problems, I found an issue while trying to create forms for some sites I have in production and ran into another issue.
It is adding the words "null undefined" right after it puts the includes at the top of the page. So, on my page, I get this at the top after running form builder:
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
null
undefined<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
