Pro Google Maps - love it
Thread begun 1/13/2011 5:08 pm by dan361748 | Last modified 1/14/2011 6:41 am by Ray Borduin | 1685 views | 2 replies |
dan361748
I've had the Super Suite for a while now but just used the Pro Google Maps for the first time.
Absolutely love it. Was easy to set up and works great.
Nice job guys. Just wanted to say.
ed.tower421027
Pro Google Map
Yah you're right it seems that way. However I used it but could not make it work.
You see when I test it via "preview in browser" I do not see any pins showing on the map nor I am able to click any address link to move the map to the required address.
Apparantly it works out good for you. Can you please let me in some of your knowledge as to how to acheive what is expected.
Please Note: I do bot have the knowledge of Java scripting and I am using dreamweaver cs4
Your assistance will be freatly appreciated.
Do you have a url where you had problems? Your google api ID is associated with a domain that it needs to run on, so if you are testing on a local machine you may need to use a api key set up to view from localhost... also you need to view it through a web server, so maybe you are browsing the file path when you preview?
The best way to have us help with an issue like this is to put the file onto a live server and give us the url to view it. That would allow us to debug and give a definitive answer.
