swf file in product description
Thread begun 1/12/2011 8:44 pm by nancy268153 | Last modified 1/14/2011 9:49 am by neilo | 7799 views | 24 replies |
nancy268153
I have created a slideshow with slideshow pro for lightroom.
I've uploaded to the server and I can see the slideshow when I go to the live URL. so far it's all working fine.
But when I try to put it into the product description using the "insert/edit flash" icon I get a broken result. "Slideshow data not found. Check XML file path..."
I know the swf file is working when I open the url with the browser but I can't seem to get it to work inside the product description?
Do I have to update some js code or paths in the XML somewhere or what?
I also cannot get it to work in another simple php page from the template which I have added to the site. I added the swf file to the page using insert/media/swf in Dreamweaver.??
this flash stuff is all new to me so I may be missing something fundamental.
I also have an html file which shows the slideshow. if I cannot get the embeded swf file to work can I somehow include that html file inside the description?
I'd like to be able to do this without the expense of Powergallery if possible.
really appreciate the help, anyone?
Nancy
neilo
Hi Nancy,
I use Slideshow Pro (and SSP Director) quite a lot in my sites, although I use the slideshow pro Photoshop plugin and slideshow pro for flash rather than LighRoom to export the images and create the xml and html file. But the principal should be the same. Either program should export the html page, the images & thumbs to specific folders, and an html page with the object code which links to the swf and the xml files.
If you could upload the working outputted html page, images folders and xml files to your server, and post a link to it here, it would be easier to say what is needed to include it in your product description page.
nancy268153
That's exactly what it does. thanks so much Neilo!
I uploaded the whole folder of stuff after making a few changes to the xml files. in each of the 2 xml files, where ever I found reference to a path, I made the path absolute by pasting in the complete http address for the referenced files.
The link to the working html file is:
https://www.nancyelizabethdesigns.com/imagesupload/cms_files/flash/hatmitt/
I have made some progress. here is an example product and how the slideshow looks in the description. it seems to just be having trouble loading the pictures.
Products_Detail.php?ProductID=34
would any of this be affect by ssl. I have just applied it and am learning how it works?
Nancy
neilo
Hiya Nancy,
My output from flash/photoshop seems to be a little different from yours, but seems to work if the paths are correct. Test item is here just to give you some hope.
I don't think there is any need to put absolute paths ssl or not, in fact I think they need to be relative to the document, as that is (as far as my example is concerned - xml path anyway) written into the actionscript inside the flash.
Not very helpful, but I do have the lightroom plugin somewhere, which I will install and then I will be able to duplicate your setup, and try for an install. When I do that (and if it is successful) then I will itemise the steps I take to make it work.
That won't be 'til later this evening, or the wee small ours though.
In fact, could you output the files again from your lightroom slideshowpro (leaving the paths just as they are created by SSP), zip the folder (html, xml, gallery/images folder(s) ) and post it here?
If it is too large to upload, then email it to me at neil (at) yeractual (dot) com.
Cheers
neilo
Just for info, for the second item, if you view the source code of the basic generated html page here
The code I took from that and entered in source view of Long Description for the new item is:
<script language="JavaScript" type="text/javascript">
AC_FL_RunContent(
'codebase', 'http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0',
'width', '320',
'height', '340',
'src', 'rySSP',
'quality', 'high',
'pluginspage', 'http://www.adobe.com/go/getflashplayer',
'align', 'middle',
'play', 'true',
'loop', 'true',
'scale', 'showall',
'wmode', 'window',
'devicefont', 'false',
'id', 'rySSP',
'bgcolor', '#ffffff',
'name', 'rySSP',
'menu', 'true',
'allowFullScreen', 'false',
'allowScriptAccess','sameDomain',
'movie', 'rySSP',
'salign', ''
); //end AC code
</script> <noscript> &lt;object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0" width="320" height="340" id="rySSP" align="middle"&gt; &lt;param name="allowScriptAccess" value="sameDomain" /&gt; &lt;param name="allowFullScreen" value="false" /&gt; &lt;param name="movie" value="sspRy/rySSP.swf" /&gt;&lt;param name="quality" value="high" /&gt;&lt;param name="bgcolor" value="#ffffff" /&gt; &lt;embed src="sspRy/rySSP.swf" quality="high" bgcolor="#ffffff" width="320" height="340" name="rySSP" align="middle" allowScriptAccess="sameDomain" allowFullScreen="false" type="application/x-shockwave-flash" pluginspage="http://www.adobe.com/go/getflashplayer" &gt;&lt;/embed&gt; &lt;/object&gt; </noscript></p>
The somewhat large javascript block (which you will see in the head area of the page source code - too long to post here) that begins:
//v1.7
// Flash Player Version Detection
I placed in the between the <head></head> tags of the Products_Details.php Page
The only difference between this one and the last one is that in the first one, all the files sat in the root directory, which would get messy if I were doing a slideshow for each item, so I created a folder in the root directory (sspRy) into which I placed the xml, swf files and the gallery/image folder. The path is reflected in the code I placed in the 'Long Description' source view code (param name="movie" value="sspRy/rySSP.swf") and (embed src="sspRy/rySSP.swf")
Cheers for now
neilo
OK,
All of the above examples will disappear for a bit, as I am redoing it for Lightroom.
Back later!
nancy268153
Wow Neilo,
You are so kind. I will pay-it-forward as soon as I am able.
Please forgive me for being so slow to get with you on this. after staying up all night working on it I'm a little behind today.
I'll get back to you ASAP with the upload and try looking at your code.
And thanks so very much for helping me
nancy268153
sending the zip of the files exactly the way they are exported from Lightroom to your email. it's too big to upload - over 6 MB
Hope this helps. :)
Nancy
neilo
No worries, I just like interfering in everyone else's business.
Forget all of the above, I have redone it with LightRoom. Example Here
Will detail my method a little later on (dinner, snooze), and offer suggestions for your own code.
In the mean time, don't send me anything as I have what I need (can't believe I haven't used the LightRoom plugin before - excellent) - but could you create a new folder in your site root called (say) lr_galleries and upload your newly exported folder into that?
Later,
Edit: - crossed posts! Will use your files for second item later on! - Will make it easier for path names etc.
nancy268153
New folder created and files uploaded. path is testshow/
take a nap;) I think i will.
