Once logged into PowerCMS admin can't see content
Thread begun 1/11/2011 2:53 pm by caryn191788 | Last modified 1/18/2011 7:03 am by neilo | 3856 views | 9 replies |
caryn191788
Good Afternoon,
Once logged into PowerCMS admin can't see content - I am unable to insert new content, view/edit or anything all the pages go to error pages.
contents_insert.php (error page)
admin/ (screen shot attached)
I can login to the admin panel but once I log in there are 3 small links at the bottom of the left square to Home View/Edit Content or Insert...
I can't go beyond this step. Currently I am trying to install 3 of these - I never had the problem when it was just CMS.
Thank you,
Caryn
Dani Chankhour
It seems that there is an error on the page. On the top of any of the admin pages, add this block of code:
ini_set('display_errors', 1);
error_reporting(E_ALL);
This should give us more information.
caryn191788
added the php script
index.php
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /mnt/Target01/332078/413816/www.texasmedicalwaste.com/web/content/powerCMS/admin/index.php:6) in /mnt/Target01/332078/413816/www.texasmedicalwaste.com/web/content/powerCMS/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /mnt/Target01/332078/413816/www.texasmedicalwaste.com/web/content/powerCMS/admin/index.php:6) in /mnt/Target01/332078/413816/www.texasmedicalwaste.com/web/content/powerCMS/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: Cannot modify header information - headers already sent by (output started at /mnt/Target01/332078/413816/www.texasmedicalwaste.com/web/content/powerCMS/admin/index.php:6) in /mnt/Target01/332078/413816/www.texasmedicalwaste.com/web/content/powerCMS/WA_SecurityAssist/Helper_PHP.php on line 67
I have 3 websites I am trying to install of these at one time. Please let me know so I can complete.
Caryn
Dani Chankhour
Try changing line 5 of Helper_PHP.php to:
@session_start();
caryn191788
changed to @session_start
Dani,
I changed the specified link. index.php
Here's the deal it is Friday afternoon and I have been trying to set up something that is supposed to be simple for 7 days. Can you call me so I can get on with it. I have to remember to log in to the forums because I don't get an email and the day is almost over.
thank you,
Caryn - 830-899-2901
Warning: require_once(../WA_SecurityAssist/@session_start(); ) [function.require-once]: failed to open stream: No such file or directory in /mnt/Target01/332078/413816/www.texasmedicalwaste.com/web/content/powerCMS/admin/index.php on line 6
Fatal error: require_once() [function.require]: Failed opening required '../WA_SecurityAssist/@session_start(); ' (include_path='.:/usr/share/pear') in /mnt/Target01/332078/413816/www.texasmedicalwaste.com/web/content/powerCMS/admin/index.php on line 6
neilo
Hi Caryn,
You may already have been contacted about this (I'm not a WebAssist Person), but as it's the weekend and staff will be few, it might be worth zipping your Admin/index.php, helper.php and posting them here.
There are a few experts who check in here most weekends who may be able to shed some light on things.
caryn191788
Zip file uploaded as suggested
Any help anyone could shed on the problem would be appreciated.
neilo
Hiya Caryn,
Please could you open the index.php file inside the admin folder of your cms (the index.php file you zipped), and replace the first 9 lines:
<?php require_once( "../WA_SecurityAssist/@session_start();" ); ?>
<?php require_once( "../WA_Globals/WA_Globals.php" ); ?>
<?php require_once( "../WA_CMS/WA_CMS.php" ); ?>
<?php require_once('../Connections/localhost.php'); ?>
with the following 8 lines:
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
Make sure that you don't leave a space between the last ?> of the block you paste in and the following block beginning <?php i.e:
(which, if you highlight it you will see no spaces). Now that should either work, or at least you should see more helpful error messages, which you could post back here.
Cheers
caryn191788
php code change
Neilo,
Thank you so very much. The code change seemed to do the trick. You have made my clients very happy.
Caryn
neilo
Cheers Caryn,
Sorry you had a bad time with this one, - glad you got it sorted out.
