No Emails sent in Test Mode
Thread begun 1/11/2011 2:37 pm by mrobben375515 | Last modified 1/19/2011 4:08 pm by Dani Chankhour | 2566 views | 5 replies |
mrobben375515
I have my site set to test mode, and no order emails are being sent. Is there a way to change that so I can test the order emails?
Dani Chankhour
Emails should still get sent in test mode. Have you already filled your email settings?
mrobben375515
I've set up all of the emails in the Admin section, and double checked to make sure I have the correct email server set. I've attached the confirm.php file just in case the email isn't getting kicked off properly. The url is order.cutestpetcontest.com
Dani Chankhour
I see the code that sends the email on your confirm page.
Are you getting the email when you are not in Test Mode? Also, what version of PowerStore are you using?
mrobben375515
It must have been an issue with the email I was trying to send it from. I switched the email and it works now. There's only one issue, it took around 30 minutes to receive it. Is there anything on my end that I can change to fix that? Thanks for the help.
Dani Chankhour
The issue depends on your Server and the Mail Server. With some mail servers it might be instant and for some it might take some time. I don't believe you can do any thing that will speed the timing. You can try sending it to different email accounts (gmail, yahoo, etc..) and see if you get a different result.
