Error after installing Security Assist
Thread begun 1/10/2011 3:42 pm by brockfam5387000 | Last modified 1/19/2011 1:06 pm by Jason Byrnes | 9662 views | 23 replies |
brockfam5387000
After installing Security Assist I went to login to the Power CMS on the same website and this is the error I am getting - can anyone help?
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/wwwecsu/public_html/powercms/WA_SecurityAssist/HelperGroupsRulesPHP.php:57) in /home/wwwecsu/public_html/powercms/WA_SecurityAssist/Helper_PHP.php on line 9
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/wwwecsu/public_html/powercms/WA_SecurityAssist/HelperGroupsRulesPHP.php:57) in /home/wwwecsu/public_html/powercms/WA_SecurityAssist/Helper_PHP.php on line 9
Fatal error: Cannot redeclare wa_authenticateuser() (previously declared in /home/wwwecsu/public_html/powercms/WA_SecurityAssist/Helper_PHP.php:19) in /home/wwwecsu/public_html/WA_SecurityAssist/Helper_PHP.php on line 48
Mike
please send a copy of the WA_SecurityAssist/HelperGroupsRulesPHP.php file so I can examine the code.
brockfam5387000
PHP File
Here is the file - thank you for helping - let me know if you need anything else
Mike
there are 2 blank lines at the very end of this file right after the closing php tag"?>", those blank lines are causing the error, please delete them.
brockfam5387000
PowerCMS still a problem
Jason, Thanks for your quick response - I removed those two lines and still getting this error when I try to login:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/wwwecsu/public_html/powercms/WA_Globals/WA_Globals.php:23) in /home/wwwecsu/public_html/powercms/WA_SecurityAssist/Helper_PHP.php on line 9
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/wwwecsu/public_html/powercms/WA_Globals/WA_Globals.php:23) in /home/wwwecsu/public_html/powercms/WA_SecurityAssist/Helper_PHP.php on line 9
Let me know what you think
Mike
this suggests something similar in the powercms/WA_Globals/WA_Globals.php file around line 23, send a copy of that file.
brockfam5387000
PHP File
Jason - here is the PHP file
this file has somehow become double spaced, download a fresh copy oit from the download center, and upload the fresh copy to your server.
brockfam5387000
Still having problems
I downloaded new file and replaced like you said but now I am getting this
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/wwwecsu/public_html/powercms/admin/users_login.php:3) in /home/wwwecsu/public_html/powercms/WA_SecurityAssist/Helper_PHP.php on line 5
Fatal error: Cannot redeclare wa_authenticateuser() (previously declared in /home/wwwecsu/public_html/powercms/WA_SecurityAssist/Helper_PHP.php:10) in /home/wwwecsu/public_html/WA_SecurityAssist/Helper_PHP.php on line 48
This all happened when I installed Security Assist
It was all working great before i installed - how can this happen?
Please help!
Thanks!
Mike
the headers already sent error means that there is output to the page it is being reported at line 3 in the last error you sent:
I'll need to see a copy of the users_login.php page to tell what is causing the error.
