Continue Shopping with Dynamic pages
Thread begun 1/10/2011 12:30 pm by bjgarner241692 | Last modified 1/11/2011 11:30 am by Jason Byrnes | 2378 views | 3 replies |
bjgarner241692
I have two links in my nav menu that takes a viewer to the productsbycat.php page with a URL variable that trims the Product list.
If they go to either category page and add a product to the cart, then hit continue shopping, it will return them to the same page. That's all good, but if they then add another product, it replaces the product in the cart with the new product. Add to Cart is in a Repeat Region. Source Code does show the distinct Product ID and it is correct.
Quick fix, I simply changed the Continue Shopping Behaviour to go to a products.php page that does not use a URL variable. Instead, it just shows all products. They can then add product and it behaves correctly.
The troube is, if they go back to the nav menu and pick one of the two category pages and add a product it will wipe out the cart contents again.
Here is the eCart code for the productsbycat.php page.
$param_products = "-1";
if (isset($_GET["Category"])) {
  $param_products = (get_magic_quotes_gpc()) ? $_GET["Category"] : addslashes($_GET["Category"]);
mysql_select_db($database_zeoconn, $zeoconn);
$query_products = sprintf("SELECT * FROM store_prodcats INNER JOIN store_prods on store_prodcats.Product = store_prods.Name WHERE store_prodcats.Category = %s", GetSQLValueString($param_products, "text"));
$products = mysql_query($query_products, $zeoconn) or die(mysql_error());
$row_products = mysql_fetch_assoc($products);
$totalRows_products = mysql_num_rows($products);
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"]))     {
$ATC_itemID $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn 0;
$ATC_RedirectAfter "cart.php";
$ATC_RedirectIfIn  "cart.php";
  if (isset(
$totalRows_products) && $totalRows_products 0)     {
$row_products WAEC_findRecordMySQL($products"ID"$ATC_itemID);
    if (
$row_products)     {
$ATC_itemName "".$row_products['Name']  ."";// column binding
$ATC_itemDescription "".$row_products['ProdSize']  ."";// column binding
$ATC_itemWeight floatval("0");// column binding
$ATC_itemQuantity "".$_POST["eCart1_1_Quantity_Add"]  ."";// column binding
$ATC_itemPrice floatval("".$row_products['ProdPrice']  ."");// column binding
mysql_data_seek($products0);
$row_products mysql_fetch_assoc($products);
$ATC_itemQuantity floatval($ATC_itemQuantity);
  if (
is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0)     {
$eCart1->AddToCart($ATC_AddIfIn$ATC_RedirectIfIn$ATC_itemID$ATC_itemName$ATC_itemDescription$ATC_itemWeight$ATC_itemQuantity$ATC_itemPrice);
    if (
$ATC_RedirectAfter != "" && $eCart1->redirStr == "")     {
$eCart1->redirStr $ATC_RedirectAfter;
    if (isset(
$_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "")  {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
    else  {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
session_commit();
if (
$eCart1->redirStr != "")     {
header("Location: ".$eCart1->redirStr);
make sure that the ID for each item being added to the cart is unique.
it sounds like the ID value being added to the cart is the Category ID, not a unique ID.
bjgarner241692
Hey, self serve solution!
I compared to another site with the same functionality and found this in the code.
$eCart1
->GetContent();
I added it to the category page and it works fine now.
Leaves me wondering though
1. why it is necessary?
2. why it is not added automatically?
The get Content line populates the cart from the session, without it, the cart is considered empty on page load.
It should be added to the page automatically, i am not able to reproduce a scenario where it is not added.
