Is there a way to show an error message id address not found ?
Thread begun 1/10/2011 10:38 am by Dave Buchholz | Last modified 1/11/2011 8:45 am by Jason Byrnes | 2374 views | 3 replies |
Dave BuchholzBeta Tester
I have a situation where I am working with a set of addresses already inserted into a database and whilst most work fine there are some that return a result like so when I view source:
/*wagmp*/
function WAMapRef(mapObj) {
this.obj = mapObj;
this.directions = false;
this.icons = [];
this.markers = [];
this.addresses = [];
this.points = [];
this.getPointByAddress = getPointByAddressFunc;
this.addressFailed = true;
return this;
function WAMapPoint(theMarker, theAddress, theIcon) {
this.icon = theIcon;
this.marker = theMarker;
this.address = theAddress;
return this;
function getPointByAddressFunc(value,attname) {
if (!attname) attname = "street";
for (var x=0; x < this.addresses.length; x++) {
if (eval("this.addresses[x]."+attname) == value) {
return WAMapPoint(this.markers[x],this.addresses[x],this.icons[x]);
return false;
function getHTTPObject(){
if (window.ActiveXObject)
return new ActiveXObject("Microsoft.XMLHTTP");
else if (window.XMLHttpRequest)
return new XMLHttpRequest();
else {
return null;
function searchCache(searchStr, zip) {
var xmlDoc = null;
if (window.ActiveXObject) {//IE
xmlDoc=new ActiveXObject("Microsoft.XMLDOM");
} else if(navigator.userAgent && navigator.userAgent.toLowerCase().indexOf('webkit') >= 0) { //webkit (Safari, Chrome)
var coordinates = '';
xmlDoc = getHTTPObject();
if(xmlDoc) {
xmlDoc.onreadystatechange = function() {
if(xmlDoc.readyState == 4) {
var x = xmlDoc.responseXML.getElementsByTagName("geocode_entry");
var geocode, id;
searchStr = searchStr.replace(/,/g, ''); //remove commas
for (i=0; i < x.length; i++) {
id = x[i].getAttribute("ID");
if (id == searchStr) {
coordinates = x[i].getElementsByTagName("geocode")[0].childNodes[0].nodeValue;
return coordinates;
xmlDoc.open("GET", "_promaps_cache/_promaps_geocache.xml", false);
xmlDoc.send(null);
return coordinates;
} else if (document.implementation.createDocument) {//gecko (Mozilla, Firefox, Opera)
xmlDoc=document.implementation.createDocument("","",null);
} else {
return '';
if (xmlDoc != null) {
xmlDoc.async=false;
try {
if(xmlDoc.load("_promaps_cache/_promaps_geocache.xml")) {
var x=xmlDoc.getElementsByTagName("geocode_entry");
var geocode, id;
return x[i].getElementsByTagName("geocode")[0].childNodes[0].nodeValue;
catch(err) {
return '';
return '';
function addToCache(fullAddress,zip, geocode){
httpObject = getHTTPObject();
if (httpObject != null) {
httpObject.open("POST", "google_javascript/promaps_geocache_php.php", true);
httpObject.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded');
var entryId = fullAddress.replace(/,/g, '');
if (zip != '') {
fullAddress = fullAddress.replace(zip+',', '');
entryId = escape(entryId);
fullAddress = escape(fullAddress);
geocode = escape(geocode);
httpObject.send("sender=promapsforgoogle&action=add&entryId="+entryId+"&address="
+fullAddress+"&geocode="+geocode);
function wagmp_map_2() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_2')) return false;
var map = new GMap2(document.getElementById('wagmp_map_2'));
wagmp_map_2_obj = new WAMapRef(map);
map.enableContinuousZoom();
map.enableDoubleClickZoom();
map.addControl(new GSmallMapControl());
map.addControl(new GScaleControl());
var geocoder = new GClientGeocoder();
var fromAddress = {
enabled: false,
street: '',
city: '',
state: '',
zip: '',
country: '',
full: ''
var icon_0 = new GIcon();
icon_0.image = 'google_javascript/images/traditionalflat_pacifica.png';
icon_0.shadow = 'google_javascript/images/traditionalflat_shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,33);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'google_javascript/images/traditionalflat_pacifica.gif';
icon_0.mozPrintImage = 'google_javascript/images/traditionalflat_pacifica_mozprint.png';
icon_0.printShadow = 'google_javascript/images/traditionalflat_shadow.gif';
icon_0.transparent = 'google_javascript/images/traditionalflat_pacifica_transparent.png';
var address_0 = {
street: '80111',
city: 'Greenwood Village',
state: 'CO',
zip: '80111',
country: 'United States',
infowindow: 'custom',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><strong>Address:</strong><br />Floyd\\'s Barbershop<br />5322 DTC Blvd., STE. 300<br />Greenwood Village <br />CO 80111</span>',
full: '80111, Greenwood Village, CO, 80111, United States',
isdefault: true,
addressType: 'address',
loop: '',
latitude: '',
longitude: '',
markerStyle: 'Google Traditional (flat)',
markerColor: 'Pacifica'
if (address_0.addressType == "coordinates") {
var cacheReturn = '';
} else {
var cacheReturn = searchCache(address_0.full, address_0.zip);
if (cacheReturn != "" || (address_0.addressType == "coordinates")) {
if(address_0.addressType == "coordinates") {
var latitude = address_0.latitude;
var longitude = address_0.longitude;
} else {
var latitude = cacheReturn.substring(1,cacheReturn.indexOf(",")-1);
var longitude = cacheReturn.substring(cacheReturn.indexOf(",")+1,(cacheReturn.length)-1);
var point = new GLatLng(latitude, longitude);
if (point && !isNaN(latitude)) {
wagmp_map_2_obj.addressFailed = false;
var marker_0 = new GMarker(point, icon_0);
GEvent.addListener(marker_0, 'click', function() {
marker_0.openInfoWindowHtml(address_0.infowindowtext);
if(!fromAddress.enabled || 'address_0' != 'address_0') {
if('address_0' == 'address_0')
map.setCenter(point, 13);
map.addOverlay(marker_0);
wagmp_map_2_obj.markers.push(marker_0);
wagmp_map_2_obj.addresses.push(address_0);
wagmp_map_2_obj.icons.push(icon_0);
wagmp_map_2_obj.points.push(point);
} else {
if (wagmp_map_2_obj.addressFailed) {
map.setCenter(new GLatLng(30, -98), 3);
wagmp_map_2_obj.addressFailed = true;
} else if (address_0.addressType == "address") {
geocoder.getLatLng (
address_0.full,
function(point) {
if(point) {
this.addressFailed = false;
addToCache(address_0.full, '', point);
} else {
var noZipAddress = address_0.full.replace((address_0.zip+','), '');
geocoder.getLatLng (noZipAddress,
function(point) {
if(point) {
addToCache(address_0.full, address_0.zip, point);
if (!fromAddress.enabled || 'address_0' != 'address_0') {
} else {
}</script>
Is there an inbuilt method that I can access to show an error message when the address fails ?
if you look in the code, you will see:
this sets the map to default to palo alto when the address lookup fails.
you could also add an alert to this so show failure:
alert('lookup of '+address_0.full+' failed');
Jason,
thanks I'll test and put a test case online for you to look at if I don't get anywhere with your suggestion.
you're welcome Dave.
