Three-Column layout, Center Column empty IE 6,7,8
Thread begun 1/08/2011 12:05 am by jcav26033 | Last modified 1/18/2011 5:19 pm by jcav26033 | 3000 views | 4 replies |
jcav26033
Can any CSS guru give me an idea of what is going on at this url:
www.embodydancesantafe.org
I am using a three-column layout from CSS Sculptor for the home page and the rest of the site is a 2-column layout from the same extension. Everything looks great on Firefox and Safari but in any version of IE 6,7,8 the only thing visible are the graphics; the text is missing. I tried placing a clear break at the end of the content div and setting a definite width for the center column based on things I read in this forum, but no luck. I am tearing my hair out on this one!
Thanks!
when i view your page in ie8 i see the following Javascript error:
Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
Line: 0
Char: 0
Code: 0
URI: embodydancesantafe.org/
It looks like you have some errors with the javascript functions applied to the page, I think the javascript errors are preventing the main content form displaying.
jcav26033
Line: 0
Char: 0
Code: 0
Jason, thanks for looking. The rest of the site, which does not have the sliding panels, and is using the 2-column layout, gives the same visual result in IE. I'll try pulling out various script elements and see if I can narrow it down. Do you get the same error on the sub-page (any page beyond home is a 2-column layout)? I will start pulling out the javascript elements and see if I can find the error.
I get the same error on each page that i visit in your site.
all pages are giving that same javascriot error in IE
jcav26033
Hi, apparently the error I was getting is rampant as a search for the error returns multiple hits. The fix for me was to move an SWFobject script that writes to a div, replacing a line of holding text with a Flash music player, outside the closing <body> tag at the end of the page. Apparently IE won't write to a child div without the parent being closed, something Safari and Firefox do without blinking. I am adding this tech info in case others encounter this error since it is a common way that Flash is written to a page. I am using SWFobject 1.5 and do not know if 2.0 addresses this browser-specific issue since the site is live and I couldn't spend time experimenting.
