Wrong number of arguments of invalid property assignment
Thread begun 1/07/2011 3:42 pm by Fritz Stickers | Last modified 11/06/2024 3:39 am by anonymous | 16279 views | 22 replies |
Fritz Stickers
I added a new column in the WA_eCart for a dropdown select menu.
Everything works fine till I "confirm".
Error :
Runtimefout Microsoft VBScript error '800a01c2'
Wrong number of arguments of invalid property assignment: 'WA_generateInsertParams'
/frogstyling/Asp/Confirm.asp, line 838
The WA_Universal_Email works fine and send the entered values correct. But value of the new column doesn't show up in the DB.
What can I do to fix this ?
is the page with the problem in the geertwijns177986.rar file? The other confirm file does not match up with the error you are reporting.
Please send a copy of the problem confirm page in a zip archive, I cannot open rar file types.
Fritz Stickers
Yes, it's that "confirm" page with the error.
The .rar is just a copy of the others, ignore it.
the error does not match to the page you sent.
the error is saying:
line 838 of the confirm page you sent is:
if (updateFieldValue = "")
this line does not use the WA_generateInsertParams function that the error is reporting the issue with.
the error and the code you sent do not match. This page could not produce that error, at least not at the line number reported in the error, perhaps a change was made to the page after reporting the error, and it is now reporting a different line number?
Fritz Stickers
sorry ... it's line 789 of the confirm page in the zipfile.
can you post a screen shot of the error message please.
Fritz Stickers
The language is dutch ... translation :
Ok, try changing line 789:
insertParamsObj = WA_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues)
insertParamsObj = WA_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, false)
Fritz Stickers
I changed it, but then I get another error :
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[Microsoft][ODBC Microsoft Access-stuurprogramma] Kan geen record toevoegen of wijzigen omdat een gerelateerde record is vereist in de tabel tblUsers.
/frogstyling/Asp/Confirm.asp, line 791
translation :
[Microsoft][ODBC Microsoft Access-driver] Cannot add or change a record because a related record is required in table tblUsers.
WA_editCmd.CommandText = "insert into " & WA_table & " (" & insertParamsObj(1) & ") values (" & insertParamsObj(2) & ")"
WA_editCmd.Execute()
WA_editCmd.ActiveConnection.Close()
end if
Also the "eCart Store Summary in Database" is gone in the Server Behaviors panel, but it's still in the code.
I checked all links in the db itself and they work fine.
That error means that you have forced referential integrity on the users table to force an associated record to be inserted at the same time. it suggests that the UserID session you are using in the UserID column is not a valid logged in user.
