Power Store 4
Thread begun 1/07/2011 12:18 pm by max363071 | Last modified 1/10/2011 4:54 pm by neilo | 3536 views | 5 replies |
max363071
Power Store 4
I need some help please.
1) After updating to PS4 and then 4.01. I am still having problems with the second page of product details. It is listing products in a single collum instead of the multi collumn formatted page. I have uploaded all the files and also run the SQL query statement.
From this page -
products_results.php?Search=1&ProductCategoryID[]=6
Click next at the bottom. The formatting is then lost.
like here -
products_results_xml.php?pageNum_WADAProducts=1&totalRows_WADAProducts=30&Search=1&ProductCategoryID[]=7
2) Featured product problem -
The learn more button is
products_detail.php?ProductID=83
Clicking the photo is
Products_Detail.php?ProductID=83
("P"roducts / "D"etails - The capitol letters is causing an error)
3) Flash video problem
I am not able to figure out how to center the ring video. I would also like to know how to loop the video.
4) After the upgrade to PS 4 / 4.01 is the database still supposed to have 16 PS3 database entries?
Thanks,
Max Arwood
1) In the download center for PowerStore, see the known Issues section for the "PowerStore 4: Support Fix - Pagination issues when PowerStore is installed in the site root "
2) In the webassist/plugins/catalog/featuredbox.php page, you can change the case of the link for the image, i am looking in my PS4 and 4.01 files and the link is the correct case, if you cannot fild the link, send a copy of your file so i can look at the code.
3) you need to center the things when creating the flash file. I have downloaded the flash movie for from that page, and the image is not centered in the movie itself. Also there appears to be some blank frames at the end which cause it to appear not to loop.
4) The update to PS4 from PS3 will not remove the ps3 tables, only convert them to ps4 allowing you to maintain the ps3 shop at the same time.
neilo
Regarding the ring video, you may have to recompile the flash, as the video (FLV) that was imported originally into the flash file was considerably larger (w, h) than the stage area of the Flash instance, and also offset to the right.
If you have problems with that, you can use the redone one here
When using the HTML Editor to insert Flash Video, you can set the loop and autostart for the swf from the advanced tabbed of the Flash Video properties window. In the normal (first) properties window, be sure to enter a proportional width and height for the swf.
max363071
Jason - Thanks
1) The PS4 is not in the root, it is in store folder.
(Here index.php)
I will try the file anyway to see if they work. I will save the other one incase they do not
2) Thanks. I think Filezilla is not doing the subdirectories when I update. Don't know how to fix this.
3) Thanks to neilo. I just need to work on it some more.
4) Thanks for the info.
Neilo - Thanks
I sure could use some help!! What you did was great. I looked at some of your work. It is fantastic! My phone numbers are on my website if your interested we could talk.
Thanks,
Max Arwood
(Snowed in tomorrow I think - 1-870-338-3326 Home Ph) Probably will not got to work.
1) Ok, let me know if the file fixes the issue.
2) If filezilla is not uploading the sub directories, you will need to do it manually.
neilo
Cheers Mark,
Happy to help in any way I can, - I can be emailed from this forum (Click my name and select 'Send email to neilo') - but most of the clever stuff comes from Jason and the WebAssist Argonauts here.
